Question about Dryers
My MDG7400AWW blows cold air, igniter clicks, sensor says moist with nothing in tub, is it the element or something else?
    President:
  • 3,074 Answers
Http://www.applianceaid.com/gas_dryer.html#noheat
Posted on May 29, 2011
Why is it blowing cold air?
A dehumidifier should blow cold air Carole. It takes in warm moist air, chills it, condenses the water out of the air and returns it chilled and dry to the room. That is the function of a dehumidifier. They often have the function of an air conditioner and blow cold air out of one outlet into the room and hot air out of the window via a venting hose. If yours is just a dehumidifier, it is working as designed
What were your expecting a dehumidifier to do?
Jan 15, 2016 | Amcor Dehumidifiers
Why is element overheating shutting my compressor off
Most equipment has security on board. When something is overheating, it can damage the machine. A sensor (thermostat) will cut power. Same thing can happen with to much moist, to high pressure, over voltage, everything that is if it becomes to high, can cause damage to the machine or to persons working with or close to the machine
Jul 07, 2014 | Air Tools & Compressors
Air conditioner not blowing cold air intermittently
you need a ac charge or the heater control valve is bad also check the compressor
May 30, 2012 | 2001 Ford Taurus
Heater only blows cold air. I have a Weather King Heater and it only blows cold air the burners will fire for about 2-10 seconds and then it goes . ...
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 09, 2011 | Weather King 10AJA3001AH Air Conditioner
Hotpoint CDT00 Tumble Drier has No Heat
you need to check the heating element also check the front drum supports they ussually wear out causing the tub to rub the element this causes the element to burn into
Jul 11, 2009 | Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
