Question about Yamaha RXV367 Receiver
We have surround sound for tv - currently the receiver does not work on the tv sound however, it does work for the tuner what do I do?
    Brigadier General:
  • 8,546 Answers
Look at some manuals for the specific models you possess. Maybe consider drawing the TV-related audio from its root source, like the Cable Box, which is indeed a high-fidelity audio device as well as a TV tuner.
Posted on May 30, 2011
How do I connect Samsung smart TV to a Yamaha receiver and get sound to come out of surround sound speakers?
Generally you will connect the Digital audio or optical audio cable from TV to the input of Receiver. Then using the remote control of Receiver you will program the source for digital audio or optical audio as TV. I am assuming the speakers on the receiver are already connected and working. All you do is then turn on TV and turn on Receiver and select TV on Receiver. The TV audio will play through the receiver. Make sure the TV sound is in Mute.
Aug 07, 2014 | Yamaha Audio Players & Recorders
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
How can i get it to play suround from tv its a LG
Surround sound will only be produced if the the broadcast TV program has suitably encoded audio. Also, even if the tuner is receiving surround sound, the TV must be equipped with digital audio out (optical or co-axial) to send to the Denon. Ensure that you don't just have stereo sound ( 2 X RCA red and white) coming from your TV.
Sep 21, 2013 | Denon AVR-3805 Receiver
How connect toshiba tv to samsung home cinema whit hdmi? i connect but still no sound. i want watch tv but listen in cinema sistem
the hdmi jack on the tv is an INPUT jack, not an output. to use your reciever for tv sound, you have to find the audio output on the tv (most do not have an audio out, but some higher end tv's have a fiber-optic digital out, which may or may not be compatible with your surround sound reciever)
if your tv does not have an audio out, the only way to get the tv sound into the styereo is to use a tuner box, like a cable box or satelite box. tuner boxes always have either hdmi or stereo audio outputs.
to use hdmi with your surround sound, you are supposed to run HDMI OUTPUT from the tuner box or disk player into the HDMI INPUT of the stereo, and then run the HDMI OUTPUT of the stereo into the HDMI INPUT of the tv.
Mar 12, 2011 | Audio Players & Recorders
I have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
No sound when playing dvd
HDMI may not output sound. Go into the setup screen of the DVD player and go into audio setup. Make sure you have it set for PCM or equivalent DIGITAL setting. If you set that and you still get no surround sound, you will have to use and optical cable between the receiver and the DVD.
Sep 06, 2008 | Audio Players & Recorders
Can't get sound with TV
reset your tuner. Call the cable co for instructions...accordianman
Apr 03, 2008 | Yamaha RX-V661 Receiver
Can't figure out how to get suround sound on tv with new home entertainmain center we do have suround sound on dvd and tuner conection just not able to conect to our panisonic tv
Look at the TV specification - does it include a surround sound receiver and amplifiers? The tuner may not be 5:1 capable - thus there is no surround on off air broadcasts. If there is then you may need to select the correct menu and turn it on - THIS WILL INVOLVE READING THE MANUAL OR USER GUIDES.
Mar 16, 2008 | Audio Players & Recorders
Yamaha RXV367 Receiver Logo
83 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
