Cars & Trucks Logo
Posted on May 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know how to fix my brake line for a 1999 buik lesabre limited edition
Anonymous
Level 2:
Sergeant:
  • Expert 159 Answers
  • Posted on May 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
159
Questions
0
Helped
111830
Points
528
I recommend getting a Haynes manual to follow when doing this repair (if you are going to do it on your own). These manuals have pictures, and very thorough instructions for repairs such as this, along with safety guidelines to make sure you are doing it properly. It will help you avoid mistakes and keep you safe on the road. I'll include a brief description of how to fix a break line, but I will probably forget to write something here, ad I don't want you to get hurt because I forgot to put in some piece of information -- so please buy the manual to make sure I have given you good information.
1. You'll need a pipe-cutter, a pipe bending tool and a pipe-flanger to do the job 2. Find the break line that is causing the problem and trace it from the breaks to the break Master cylinder. 3. Take a piece of steel pipe (standard break line) and use the pipe-bending tool to shape it to look exactly like the pipe you are replacing and use the pipe cutter to cut it to length (if you don't use a bending tool or a pipe cutter, you can cause a crimp in the line and your breaks will not work) 4. If you are replacing the entire line (recommended) remove the line from the breaks and drain off the fluid. 5. Flange (widen the pipe end) your break line at the end closest to the breaks so that it fits over the connector (like the previous break line was). 6. Connect the new break line to the breaks using a new connector (same type as the previous break line. Make sure that the rest of the break line is supported near the original line to keep from ruining the new line -- if it bends or crimps your breaks may not work. 7. Remove the old line from the mounting brackets one at a time, and replace it with the new one as you make your way up the line to the front of the car. Doing this one bracket at a time will help you make sure you are mounting it properly, and gives you a chance to inspect the mounting brackets as you go. If a bracket is bad (and won't secure the line) replace the bracket with a new one -- you don't want your new break line falling down and getting ripped off your car when you hit a pothole. 8. Once you get the line mounted all the way to the master cylinder, complete the removal of the old line, and attach the new one like you did at the breaks-end of the line. 9. Double-check all of your connections and make sure the mounting brackets are all tight, then bleed the break line to remove the air. (it's probably best to bleed ALL of the break lines to make sure you have not introduced a bubble anywhere -- this can keep your breaks from working properly) 10. Once the lines are bled, and everything seems to be in order, jump in the car and hit the breaks REALLY hard -- like you are slamming your breaks to save your life. Check the lines again to make sure they did not leak anywhere (especially at your connections where you had to flange the pipe). If there are no leaks, you should be good to go. If there is even a small leak anywhere in the line or at your connections you should go over the connections again to make sure they are secure. Once you have your lines tight, bled and have double checked that you can slam the breaks without causing a leak, you should be good to go.
I do not recommend doing this work yourself -- it is very difficult to do without a professional lift (as you will need space to work and jack stands don't give you much room). It is also a VITAL part to the safety of everyone in the car ... and if you don't have a lot of experience it is easy to miss something and put yourself at risk. A professional shop and get this job done in a lot less time, and with a lot less risk than an at-home mechanic, so it is probably worth the price. As I said before, the 10 steps above are a GENERAL OVERVIEW of the process -- not an exact science to follow -- I probably forgot to put some information there ... so PLEASE (if you are going to do the work yourself) get a manual to be sure you have all of the steps correct. I HIGHLY recommend that you take it to a mechanic, though (I do a lot of my own car repairs, but I don't trust myself with the break lines -- they are too vital to my safety ... and a pain in the neck to replace without the right equipment)
1998 buick lesabre limited edition brake line diagram
As far as I know there isn't one and I've never seen one in all the repairs I've made on these cars. You have to just visually follow the actual metal brake lines from the wheels to the ABS controller and back to the master. Odds are unless you have an actual fluid leak in one of these lines that you have a different issue if you are having a brake problem.
Buik regal 90' limited dome light stays on when
The activation switch at the door is bad or stuck. Buy a new or used one or take it out n un plug it. Tape the end.
I have a 1995 Buick Lesabre limited. I need the brake line from master cy to the distribution box. Dealer said it is discontinued and local NAPA has a different type of thread. Where can I get the...
take the line off,go to autozone ,even if the ends don't match,if you can find 2 different lines with the correct ends ,buy a splice and build your own.
What is the size of the brake lines on a 1995 Buick Lesabre Limited ? i need the nuts/bolts for the proportioning valves and do not know what size the brake line is so i know the proper ones to...
best advice i give here that works for me is to remove the parts and then take them in my hand to the auto factor then i always get the right ones,sometimes on a vehicle of the same year their can be three different suppliers parts fitted causing no end of problems on the spares side so old ones in my hand and off i go
2helpful
2answers
What size are stock tires for this car?
1999 Buick LeSabre Custom Front and Rear Tires P205/70R15
1999 Buick LeSabre Limited Front and Rear Tires P205/70R15
1999 Buick LeSabre PP (*) Front and Rear Tires P215/60R16
(*) PP = Performance Package
Other details can find in the Buick-Lesabre-Owners-Manual
Hope helps (remember rated and comment this).
How to plug rear brake line?
Typically front line on the master cylinder goes to the rear.
3helpful
I need a new brake booster for my 89 LeSabre T Type. I i don't know if I need the entire thing or just the cylinder. I have no pressure with my brakes, even with the brake fluid full. I know i have a leak...
booster rarely go bad and when they do they make a vacuum sound in the car see if vac hose is going to booster from top back of engine 2 booster if that is got vac . but the leak in the brake line is a bigger danger and you cannot diagnose the master or booster with out fixing that leak first &bleading the brakes
1helpful
Diagran for a buik lesabre
Go to the autozone.com website and register the vehicle information. It's free and will give you access to an online repair manual for the car. It's not a diagram, but it certainly is a handy resource for anyone planning to do maintenance on their vehicle. Hope this helped and best wishes.
1helpful
2answers
1999 jeep cherokee limited- no pressure when I press break down, small leak beneath left tire I re-filled brake fluid, what should I do next?
you need to bleed the brakes,,get any air in the system out.....but make sure you fix that leak or the pipe or what ever is wrong first,,,,then get help bleeding the brakes ,,,you kinda have to no how to bleed them though you need 2 people one pumping the brakes the other bleeding the calipers,,,,
Top Buick Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
