Question about Hardware & Accessories
Cannot set timer oven willnot work stuck on auto
    Scholar:
  • 122 Answers
Most modern oven timers require that the clock be set before the timer will operate properly.
Posted on Jun 07, 2011
Does not heat
Turn it on Just joking you need to put more details than that is it electric or gas does it have a make or model is the timer set or is it stuck on auto if its a manual timer turn it on to say 10 minutes does the oven work then if so you need to turn it to the manual setting Regards Geoff Stove Recyclers
May 28, 2011 | Ovens
Creda concept solar plus oven timer
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Creda Ovens
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
Bottom fan oven not getting power but top oven/grill is working
Check that the oven is not stuck in AUTO or TIMED mode. Also set the clock to the correct time if you can.
Nov 05, 2008 | Ovens
Auto light wont fo off
good day,
hope this link below will solve your problem.
ovens
Aug 15, 2008 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Apr 05, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Ovens on cooker
DEPENDS ON THE MAKE AND MODEL EACH TIMER OPERATES DIFFERENTLY, BEST SOLUTION IF YOU DONT USE THE AUTO FUNCTION IS TO HAVE THE TIMER WIRED OUT SO OVEN COMES ON REGARDLESS IF THE TIMER IS SET OR NOT.
Feb 14, 2008 | Ovens
Auto Timer
hi there switch your oven off at the mains switch for one minute thenswitch back on and set the time this will disable the auto on the timer.
Dec 09, 2007 | Neff U1661 Double circotherm super...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
