Question about Zanussi ZWF1640 Front Load Washer
Zanussi ZWF 1640 - error message 41 can you help
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
E20 is "A problem with water draining" Solutions: The drain hose may be squashed or kinked The drain pump may be blocked
Posted on May 21, 2007
  • 1294 Answers
SOURCE: error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Posted on Jan 12, 2008
SOURCE: E60 error code
Our machine - a ZWF1437 - has developed the same problem. Our friendly engineer has checked his manual and told us that there is no such error code. He suggested switching the machine off and unplugging it to allow any residual charge to clear from the memory chip. The next step is to clean out the filter at the front - remember to empty the water out first. After a couple of hours, switch the machine on, press reset and then spin to empty any remaining water. Hopefully, this could work ---it didn't work on ours but he assures me that this tip usually works.
Posted on Jan 24, 2008
  • 249 Answers
SOURCE: zanussi zwf 1440
Something wrong with the pump,leave out let hose down as flat as possable into a basin or whatever,to drain water,remove pump test and check it.
Posted on Dec 02, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
My problem is the machine makes a noise as if a piece of cardboard is rubbing at one particular point each revolution of the drum it has now become quite loud on my zanussi zwf 1632 w can anyone help ?
I may just be lucky or it might just be temporary but the fault has cleared on my zanussi zwf 1632 w. washing machine thanks for the offers of help if needed in future i will certainly contact FixYa."Bill 34"
Sep 19, 2009 | Washing Machines
Help with zanussi it wont fill with water
you need to know the error, but could be low insulation heaters....you need to find error message which zanuzzi engineer will find
Jul 15, 2009 | Washing Machines
Zanussi zwf 1440
Sep 05, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi zwf 1432 front loader
check the filter down on the right and cleane it
May 28, 2008 | Zanussi ZWF1430W Front Load Washer
Error code e30
Dec 04, 2007 | Zanussi FJS1225W Front Load Washer
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1640 Front Load Washer Logo
56 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
