Question about MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard
Have changed the tower, but forgot were the power, hdd and reset cables fit
    President:
  • 1,851 Answers
Assuming the motherboard is here:
the details for the connectors are here:
In case you'd like the full user manual you can download it in zip format from this official link.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 29, 2011
  • joecoolvette
    joecoolvette May 29, 2011
    Now THAT is a SOLUTION, Stelios!! Good Job! Regards, joecoolvette
  • Stelios
    Stelios May 29, 2011
    Thanks for your comment.
    You're welcome at fixya anytime you need our help.
    Thanks and regards
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
I have a HP Pavilion a450n and would like to know how to change hard drive. I looked at and think I know how but I am worried about breaking the green plastic. Anyone help me?
turn of pc, Remove from hdd cabeles, there is two, change you hdd and out cables in their place, you can not put power cable to another palce, there is all have their place, for example you can not put hdd power cable to hdd Ide otr Sata port.
Jun 13, 2011 | HP Pavilion a450n PC Desktop
Forgot user password and could not reset it in bios, my admin is set. Do I have to reset the jumpers? HP Pavillion laptop
no need. just remove the cmos battery and the power cable on the tower, then hold the power botton for 15 seconds and then wait for 2 minutes before you plug the battery and the power cable back in, it should reset the bios and the pw should be remove
Mar 27, 2011 | Computers & Internet
Power button on dell dimension 8200 is solid amber computer will not boot up what is it?
hi this looks like the hdd is not powering up...take the cover of the tower and disconnect the hdd power and see if the motherboard fires up on its owen......unplug the power to the motherboard and wait 5 mins plug it back in see what happens.......on the motherboard were you plug in the hdd led cables and power cable and the led cables and fined the one that has the pwr on it plug it in on its owen see if that helps you
Nov 12, 2010 | Dell Dimension 8200 PC Desktop
Just bought a new tower case and cannot figure out where to plug in the power switch, reset switch, power LED and HDD LED wires.
With reference of your motherboard posted picture, opposite pci slot you will find a ten pin male slot where you can place your hdd, power, reset jack connection of your cabinet
Oct 06, 2010 | MSI K8N Neo4-F Motherboard
Dell Asus M2N61-AX MB front panel connector Nix ATX Gaming case
I assume you mean the HDD,reset,on switch etc where they plug onto the mobo.
Most mobos are labelled on the board but you will need good eyesight to read. They are labelled HDD, RESET, SPEAKER etc.
If not simply look up mobo manual from vendors site. You will need the DELL serial / part number from the old unit though.
Apr 29, 2010 | ASUS Computers & Internet
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
I bought the hp slimline s3707c a few months ago and I love it! But due to me being a huge gamer I needed to upgrade my Vid Card. The new card doesn't fit in the tower so I bought a bigger tower and was...
My best suggestion is to get a professional installer to do it for you.
If you want to do it yourself.
  1. take the top of (make sure to ground yourself) and DONT work on carpet if possible. Static is bad!
  2. the HP is nice in the way that it has sliding internal features. So some of the chasis will slide out of the way. Take advantage of this.
  3. BEFORE you take ANYTHING APART make sure the mounting screws of the motherboard line up with the mounting area of your newly bought CASE. Also, make sure output on powersupply on new case comparable to your existing one, and that connector wll fit your MotherBoard.
  4. disconnect all power supply wires
  5. take out Power supply which will give you more room
  6. disconnect ribbon cables (or SATA), remove them.
  7. unscrew mounting screws on motherboard and put it in your new case. Make sure MotherBoard does NOT ground to your case (IE it should not wiggle around) and be put in securely
  8. remove peripherals from your old case and put in your new case (HDD, CDROM, etc.)
  9. connect power supply cables, then ribbon cables (or SATA if so)
  10. Put case together and connect wires in back (Monitor, keboard, etc.)
  11. Your are done, Congratulations!
Nov 09, 2009 | Computers & Internet
LED Connections on a basic brand Motherboard
Here is a link to the manual for that particular motherboard.
pdf Manual
Hope this helps
Sep 24, 2009 | IBM Aptiva E 2170 PC Desktop
I have the same problem. "No Input Signal"
may be the power button get stuck when you pressing to switch on.just change the power button cable with reset button and see. also chek the **** aslo just remove it and clean it and fix it again.
Sep 10, 2009 | HP L1706 17" LCD Monitor
Replaced hdd on emachine w3615,light on mobo but it wont come on.
Hi ipackrat21, that little green led you see is telling you the motherboard has standby power. (Its supposed to be green & on).
Make sure the hdd jumper is set to, master without a slave). In a one hdd system.
When you replaced the hdd you also need to enter the bios menu.
In the bios you'll need to make some changes. First you should see the new hdd listed in the bios. (Normally it list the hdd by model). If your hdd is shown than go to the title "BOOT". You need to set the boot order. A normal boot order would list like so;
First boot device, Floppy disk drive".
Second boot device, "CR-ROM" drive.
Third boot device, "Your new hdd".
If your bios does not see your hdd you'll need to re-check the data cable from the board to the drive. (Make sure it is fully connected).
If the drive is an IDE/PATA make sure it has power. A 4-pin molex.
010e000.jpg Good luck ipackrat21!
Still have trouble, post it here.
Mike
Jan 14, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard Logo
834 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
