Question about NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
Does the wndr3400 support ipv6? - NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
  • 58 Answers
Netgear WNDR3400 does not support ipv6.
Posted on May 30, 2011
  • Darryl Baker
    Darryl Baker Aug 20, 2011
    But according the the Netgear web site with the latest firmware it is supposed to.
    http://support.netgear.com/app/answers/d...
Firmware update 5102g
The firmware WNDR3400 Firmware Version 1.0.0.52 and instructions are here.
NETGEAR Support Answer WNDR3400 Firmware Version 1 0 0 52
Mar 08, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
Hp laserjet P2055dn - print config report indicates IPv6 Address, will not network print. How can I clear this?
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
Nov 19, 2011 | HP Office Equipment & Supplies
I need to know if paradyne 2600 is ipv6 compatible
On bridge mode, DSLAM and modem are transparent to IPv6.
On routing mode, IPv6 is not supported yet.
Pls correct me if im wrong, tq
May 03, 2011 | Paradyne BitStorm 2600 (2611-a1-430)
Does Linksys Wireless g wrt54G router support ipv6?
With the standard Linksys firmware, it does not. Some versions of the third party firmware from DD-WRT and Tomato support IPv6, but the configuration you would use depends on how you plan to use IPv6 (native, tunnel, etc).
The common ways to use IPv6 are in native mode or tunneled (6to4, 6rd or 6in4) mode.
Mar 31, 2011 | Linksys Wireless-G WRT54G Router
I want to know if the WN111 will be compatible to my new WNDR3400 router
Well, I know this may be solved by now (Hope so anyway, right???) but YES IT DOES !! I just set up our new WNDR3400 this evening and my son has 240 Mbps through a Netgear WN111 out in the garage (approx. 75 ft. away...)
Jan 20, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
GETCE6B1, Internet Protocol Version 6 Not Available
The 'IPV4' (Internet Protocol Version 4) was designed for a world with 4 billion unique devices (desktops, laptops, netbooks, iPod Touch/Phone, IP-TV, cell-phones, et cetera).
That limit is being reached!
The newer 'IPV6' (Internet Protocol Version 6) was designed to give a unique IPV6 address for EVERY SQUARE INCH of surface of our planet.
So, if your computer is "talking" to an IPV6 device (router or modem), you should _NOT_ get "IPV6 not available". However, if your computer is "talking" using IPV4, you probably _WILL_ get the IPV6 not available" message.
No big deal. If your computer cannot "talk" IPV6, then it should "talk" IPV4.
Jan 18, 2011 | Sylvania G-Netbook
When my computer wakes up it sometimes gives me an error that there is an IP address conflict and will not connect to internet. I have 1 oe 2 laptops and 2 direct tv recoders attached.
Hi, Lets we disable your IPV6 to IP V4 only .
Do you know how to disable IPv6 in Windows Vistair?t=homnetwirneta-20&l=ur2&o=1? Do you know it's enabled by default? It's pretty simple actually! As I know some might even want to uninstall IPv6, but you won't be able to do it as this is built-in feature in Vista kernel. Although IPv6 is developed with better security and aimed to overcome the shortage of IPv4 addresses, but there are several reasons why people still wish to disable this feature:
- Totally not going to use this IPv6 feature as it's not that popular yet and don't know how to use it
- Disabling this IPv6 feature can conserve Windows' CPU and memory resources
- Better network performance with disabled IPv6 feature
Somehow there are still some disadvantages for disabling this IPv6 feature: you will not be able to use Windows Meeting Space or any application that relies on the Windows Peer-to-Peer Networking platform or the Teredo transition technology. If you are not going to be affected by those disadvantages, let's proceed to do it:
1) Go to Start and right click on Network and then click Properties.
2) Network and Sharing Center window will appear, after that click Manage network connections.
3) Network Connections window will appears. Here you can right click on the network card that you wish to disable IPv6 and click Properties.
4) In the Local Area Connection Properties window, untick Internet Protocol Version 6 (TCP/IPv6) and click OK.
Note: This method disables IPv6 on your LAN interfaces and connections, but does not disable IPv6 on tunnel interfaces or the IPv6 loopback interface. You need to make change in Windows registry in order to disable the IPv6 on tunnel interface. You can stop here if don't feel like working with Windows registry. If not, proceed with Step 5.
5) Type regedit in command prompt in order to launch registry editor.
6) Registry editor will appear, proceed to locate following registry item:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip6\Parameters\DisabledComponents
Note: If the DisabledComponents item is unavailable, you must create it:
a) In the Edit menu, go to New, and then click DWORD (32-bit) Value.
b) Type DisabledComponents, and then press ENTER.
7) Double-click DisabledComponents, set the value as 0xffffffff (hexadecimal value) (just type ffffffff) to disable IPv6 on LAN interfaces, connections, and tunnel interfaces except the IPv6 loopback interface, finally click OK.
8) You must restart the computer for this registry value to take effect.
Dec 19, 2010 | Belkin Wireless Surf Router (F7D2301)
Ipv6 no connection
thomasrob184
In regards to your question aboout IPV6 this is not standard that is supported yet. IPV6 is s future technology that his been added so that when this becomes a standard your current hardware will work with it.
So if you are having network trouble it should not be related to IPV6. If you can let me know some more about your problem I can see what I can do to address your issue.
Issken
http://www.fixya.com/users/issken
May 02, 2010 | Gateway (SOLO200ETHERNET) Network Adapter
What is ... '' Teredo Tunneling Pseudo-Interface , something to do with IPv6 as part of networking ??
Teredo is an IPv6 transition technology that provides address assignment and host-to-host automatic tunneling for unicast IPv6 traffic when IPv6/IPv4 hosts are located behind one or multiple IPv4 network address translators (NATs). To traverse IPv4 NATs, IPv6 packets are sent as IPv4-based User Datagram Protocol (UDP) messages. This article provides an overview of Teredo—including Teredo addresses and packet structures—and detailed explanations of how communication is initiated between Teredo clients, Teredo host-specific relays, and IPv6-only hosts using the IPv4 Internet, the IPv6 Internet, Teredo servers, and Teredo relays.
more at http://technet.microsoft.com/en-us/network/cc917486.aspx
Dec 31, 2009 | Computers & Internet
NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
971 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
