We have teco 7200gs type and while running there is an error occured " fault ground short " what shall we do i need answer immediately
2 Suggested Answers
  • 35 Answers
SOURCE: Volvo V-70 drivetrain & electronics faults
I suspect you have some loose connections or shorts in the wiring harness. I've had similar strange things happen with an Olds Bravada. Various transmission shifting problems, faults, etc. that all seemed to come from the engine's computer system getting incorrect voltages and readings due to wiring faults/shorts.
Posted on Dec 16, 2011
Testimonial: "Thanks, Trouble is Volvo dealer does not seem to know how to fix the issue."
What does E2 mean on a Teco washing machine
Check to be sure the drain hose on your TECO washer is not crimped or bent thus preventing water from exiting. Check that the drain pump is not jammed or obstructed in any way as this will cause the washer to not drain and the error code will occur. Washing Machine Error Codes Front Load and Top Load Washers l
Teco is not listed but the comments include the answer.
Jun 05, 2017 | Washing Machines
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Sewing machine tension
the tension dial may need to be replaced, it would be a good
idea to have the machine checked
Feb 06, 2013 | Sewing Machines
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
Jun 30, 2012 | Computers & Internet
Dec 16, 2011 | Cars & Trucks
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
SEQUENCE (cont.)
(t02)
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
How far from the shower head do recessed lights have to be fitted
552.54 Luminaires.
((B) Shower Luminaires. If a luminaire is provided over a bathtub or in a shower stall, it shall be of the enclosed and gasketed type and listed for the type of installation, and it shall be ground-fault circuit-interrupter protected.
The switch for shower luminaires and exhaust fans, located over a tub or in a shower stall, shall be located outside the tub or shower space.
Essentially there is no distance specified BUT the fixture must be sealed AND protected with a GFCI
Nov 17, 2009 | Westwind Classic Hugger Polished Brass 52"...
When I want to open a PDF File sent to me from anywhere, my internet freezes immediately(every time!!) & says "Adobe has experienced an error & has to shut down". At which point, the...
uninstall adobe and go to google and type in free download for adobe reader it will give you alot of hits but pick the first one, you will have to reinstall it but it will give you the newest adobe reader
thanks tazman
hope this works for you
Aug 19, 2008 | Computers & Internet
GE Dryer error code E61
SEQUENCE (cont.)
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
Mar 16, 2007 | GE DBVH512EFWW Dryer
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
