Question about Garden
Murray 1700 turns over but no spark - Garden
    President:
  • 3,074 Answers
Either its the kill switch( the red bar you pull) is not breaking contact and grounding out the magneto/coil or the magneto/coil is bad. Tim
Posted on May 29, 2011
Murray string trimmer will not start. Compression 80#
If you are not getting any reaction from starting fluid the spark plug must be at fault. Two cycle engines are pretty ******* plugs.
Sep 03, 2017 | Murray Garden
2009 vulcan 1700 won't start. ran a week ago. has half tank of gas.
It turns over, with no start. It will either be fuel or ignition.
I understand from your description this machine has been sitting for some time. If the fuel is over a year old, drain it and flush the tank and carburetor. There is a lot of residue that occurs from evaporated fuel, mostly varnish.
Check the ignition by pulling a spark plug wire and visually verify the spark to the frame.
Remove and clean and set the spark plugs and re-torque.
Aug 17, 2015 | 2009 kawasaki Vulcan 1700 Classic
I have a Murray 30" riding mower with a Tecumseh TVM195 8hp engine that won't start. The engine seems to be locked. I have removed the spark plug and tried to turn it, but it is still locked tight. The...
Maybe the rope pull start is stuck? Remove shroud and see if you can rotate the flywheel by hand. If it won't move then the crankshaft may be stuck on a broken part, such as the governor gear or camshaft that has broken off.
Aug 04, 2014 | Murray Garden
Spark plug size for murray convertible mulcher
Can you tell me model and brand of engine?
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Jul 21, 2013 | Murray Garden
Murray 10/30 riding mower has spark but not firing, with a puffing sound out the air filter when trying to start it.
Gavin, the symptoms indicate that the intake valve is stuck open, it could be that the exhaust is also stuck, but normally when an engine sets up, only one stem corrodes and gets stuck. It matters little though which one is stuck, you will still need to have a valve job.
junkl
Feb 26, 2013 | Murray Garden
Hello i have a 14.5 hp murray riding mower well when u take the spark plugout the motor cranks over just fine but when u put the spark plug back the motor will only hurn a half turn can u plz help me
You might have interferance with the piston, is the spark plug is too long? If it is the same as original, then the flywheel key may be sheered and causing the spark to be out of time and firing before reaching full compression. \
Other than that, a weak battery or starter could be insufficient to overcome the compression and allow it to start.
To test this, put a jumper or charger on the battery, then by hand rotate the engine backwards until it gets to hard to turn by hand, this will be on the exhaust stroke. When you try to start from this position, there may be enough momentum to overcome a weak starting system. (Mine has the exact same problem)
junkl
Dec 15, 2012 | Murray Garden
Trouble starting murray riding mower model # 42560x92a
it has to be ignition coil or gas feed ckeck coil by removeing spark plug leave coil wire connected turn mower over see if you have spark if so it is in fuel delivery if not check and be sure ground is releasing on the flywheel brake if it is then check fuel filter if ok rebuild and clean carburator.
Jul 31, 2012 | Murray Garden
Need some spark in my life
Check your start fuse. Its a 20 or 30 amp. Just behind engine.
May 25, 2012 | Murray Garden
Murray riding mower won't starter, new solenoid, new spark plug and trying start it from the start turn over but won't start and try from the solenoid still no go.
You need to pull the spark plug out, connect the spark plug wire and ground the plug to the motor and see if you have spark. If you have spark (bright blue) then it is a fuel problem. A yellow spark is and indicator of a coil issue.
Aug 25, 2011 | Garden
What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Jun 26, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
