Question about Garden
I have a Harbor Freight 2 HP, 8 Gal, hot dog style air compressor. The model # is 95386. It has only about 2 hours use. It has the proper amount of oil. It has worked well until just recently. Now, it compresses air, but it stops at 20 pounds of pressure. It doesn't turn off. The switch doesn't stop the unit. It just keeps running, but doesn't create any higher pressure than 20 pounds. I called Harbor Freight tech support. They said that it is probably the head gasket. I removed the head. The gaskets look perfect. I looked at the cylinder bore. No scuffing. The rings look fine on the piston. I reinstalled the head and torqued the four head bolts to 12 ft lbs each.
  • richardnday Jun 01, 2011
    Unfortunately, the head area is cooled by the fan on the motor. Consequently, I cannot turn off the cooling air even for a short time. I have felt around possible areas of leaking, but I cannot feel nor hear where the air is going.
  • 43,501 Answers
If the air pressure will not go higher then 20 PSI and the compressor is still pumping air then it is going somewhere.... to find the leak I would feel for the escaping air... if you cannot feel it then take something like an old rope...light it on fire and then snuff it out so it will smoke... then hold that different places around the compressor while running to see where the air is coming out at...you will see the smoke blow when you get near the leak...
heatman101
Posted on May 30, 2011
Am out of oIL to put in a campbell hausfeld 20 gallon 4.5horsepower air compressor
Google the model number, download a copy of the owner's manual, follow directions. Try searching that model number at harborfreight.com If the manual does not exist anymore, and the pump has a sight glass, fill with clean, non-detergent straight 30wt motor oil, available at most car parts stores. If there is no sight glass, drain what is in there and pour in 1/2 qt. No promises that is right, but it is likely close. Last option, go to a Harbor Freight store. Look for a compressor with a pump that looks like yours on size and shape. look at that manual and use that amount of oil. Good luck
Sep 28, 2015 | Campbell Hausfeld Air Tools & Compressors
I have central pneumatic 21 gal. air compressor. The unloader valve is broke. The power switch is a fenwai model: fw-10. Where can I buy a new unloader valve?
If you should mean the switch that is pressure controlled that turn the compressor on and off- that is a fairly universal replacement piece, As is the power switch itself
If you needed that specific part, your best bet is Harbor Freight tools who owns the Central Pneumatic domain.
Feb 14, 2012 | Air Tools & Compressors
The clutch on my air conditioner compressor went out. Can I tackle a fix by myself?
With the proper tools, a person can change the compressor clutch. Make sure you get the right clutch assembly and then it's a matter of getting the right tools to remove/install the clutch. I bought a set from Harbor Freight and it has served me well. I am not connected in any way to harbor freight and the same set of tools should be available form most any auto parts store.
Sep 11, 2011 | 2000 Chevrolet Suburban
Hi were can I buy a spray gun for dewalt compressor
Anywhere, really....Sears, Home Depot, Lowe's, Harbor Freight, just about anywhere....even WalMart.
May 12, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
How much oil for 2hp 8 gallon central pneumatic air #95386
i'm not sure of the solution but what type of oil did you use?
Apr 10, 2010 | Air Tools & Compressors
What weight oil do I use. New compressor not used
30 weight non detergent. Sears has this oil on the shelf or you can get the same at any auto parts place.
Non detergent is the key.
Refer to your owners manual for further information
Thank you for your service.
Oct 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I am missing the screw in drain plug for a Model 95386 air comp.
this is normal item at parts house, anyway why do have a plug. i put a small ball valve much better i got at home depot
Jul 02, 2009 | Air Tools & Compressors
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
