Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
HE4T F06 ERROR
EVERYTHING WAS FINE FOR 2 YEARS AND 7 DAYS AS THE STORY GOES. THEN A BALANCE PROBLEM EMERGED WHEN I DID A SUPER LOAD OF TOWELS CAUSING THE DRUM TO SHAKE SO HARD IT FORCED THE DOOR OPEN BREAKING THE DOOR LOCK MECHANISM. I REPLACED THE DOOR LOCK MECHANISM AND ALL WAS WELL ALTHOUGH I NOTICED BALANCE ISSUES WITH LARGE LOADS BUT COULD COMPLETE LIGHT LOADS WITHOUT INTERUPTION. THEN I GOT THE DREADED F11. I PLAYED IT SAFE AND REPLACED BOTH THE CCU AND MCU IN THAT ORDER. AFTER CHANGING THE CCU THERE WAS NO CHANGE IN F11 STATUS. AFTER CHANGING THE MCU THE F11 CLEARED. WHILE I WAS DOWN THERE, I NOTICED THE FRONT 2 SHOCK ABSORBERS HAD BECOME UNATTACHED AT THE TOP SO I RE-INSERTED THEM. (WISH I HAD CHECKED THAT WHEN THIS WHOLE THING STARTED). AFTER THE MCU WAS SWITCHED THE F11 CLEARED BUT UPON THE FIRST TEST CYCLE THE F06 NOW APPEARED. SEEMS THAT AFTER WATER STARTS TO FILL FOR A FEW SECONDS THE MOTOR ENGAGES TO TURN THE DRUM FOR A FEW SECONDS AND THEN STOPS. IT DOES THIS 3 TIMES AND THEN DISPLAYS F06. I AM NOT VERY HANDY IN THE ELECTRICAL DEPARTMENT AND DONT KNOW HOW TO TEST THE MOTOR'S AMPS/OHMS BUT CAN DO OTHER PRELIMINARY CHECKS. NO LOOSE WIRES OR CONNECTIONS FOUND ANYWHERE. I ALSO CHECKED THE PUMP WASH OUT AND PROPELLERS FOR OBSTRUCTIONS AND FOUND NONE.
  • ONE4BRI Aug 23, 2008
    "UNLESS YOU PURCHASED BAD REPLACEMENT PARTS" RIGHT ON...THE MCU I BOUGHT OVER THE INTERNET WAS BAD. ONCE I REPLACED IT WITH ANOTHER ONE. EVERYTHING WAS FINE! THANKS
  • 5,911 Answers
Wow. Sounds like you've had your hands full with this one. Well, since you've already gone the route of replacing the CCU and MCU, more than likely you have a wiring harness problem and/or drive motor issue (as you have already explained). The following link explains the "F06" error and how to troublehoot:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Review the information and double check to make sure you have overlooked anything. Unless, you have purchased defective replacement parts, I can only assume the motor and wiring. Unplug the washer and perform resistance checks on the motor windings. If you have a multimeter handy, this would be on the RX1 scale. The pin locations are mentioned in the link provided. Each motor winding should read 6 ohms or less. On another note, the vibration problem you mention, was definitely caused by the shocks not being mounted properly. You may consider replacing them, since you said you're still experiencing vibration issues.
If you are still confused by anything, please let me know. I hope this helps you.
Posted on Aug 16, 2008
Kenmore He4t front load washer f 06 error code
This answer is actually from Sears Parts Direct: The F06 error code
indicates a drive motor tachometer error. This error is virtually impossible to accurately diagnose. The most suspect components that would cause this failure code are the drive motor, the motor control unit (control board) or the wire harness. In some instances, this could be caused by severely overloading the washer so that it cannot spin properly. Make sure that the washer is not overloaded. Another problem that could cause the error code to be displayed intermittently would be a loose wire harness connection that is affected by vibration when the washer is spinning at high speed. Good lucks, hope it helps
Dec 07, 2014 | Washing Machines
I have the F06 error code on my he4t washer. I've checked online with all of these "fix it" sites and had an electrician check the motor. All of the connections and the motor are fine. How...
The MCU is the motor control unit its in the lower panel down on the bottom
The CCU is the central control unit and it is up in the top behind the touchpad/cycle selector
Sep 23, 2011 | Kenmore Elite 45986 Front Load Washer
Clothes come out super wet
Drive motor failure, CCU or Motor control failure. To ceck this look at your owners manual and from then test the parts with a multi meter. To keep from spending money you can unplug your machine for 15 to 30 minutes, plug it back in and sometimes that will clear the code and everything will work just fine. Also some parts are covered under the 5 year warranty so make sure about that also
Apr 17, 2009 | Kenmore Elite 45986 Front Load Washer
HE4t Washer
"F06" is a Motor Speed error. The following link explains how to troubleshoot and some common causes:
The first step to troublehsooting should be to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches with the unit. If the error code reappears following a computer reset, follow the advice given in the link I provided.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T Elite F06 problems
Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
WILL HE4T RUN WITH KICK PANEL AND BACK PANEL OFF?
The washer will run without the panels in place. As a technician it is common practice to troubleshoot with the bottom panel and/or back panel removed in order to see if certain components are working. The "F06" error is a motor speed problem. With this fault, the washer will shut down if the motor speed is not detected, or reach optimum rpms. The fault is usually caused by a failure of the Motor Control Unit (MCU) or Drive Motor. The following link explains how to troubleshoot:
If you require addtional assistance, please let me know. I hope this helps you.
Aug 17, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
KENMORE HE4T STARTED AS BALANCE AND F11 NOW ITS F06
ck all the connectors to both boards and motor you may have inadverantly left 1 loose or knocked one off during previous repair
Aug 16, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
W/pool awm8143 not finishing cycle fault F06 flashing on display
I had this same problem, an intermittent F06 fault.  The F06 code means a tachometer fault.  After some fault-finding, I did manage to fix it.  If this error code happens to you and you know a bit about electronics, try taking apart the timer and looking for dry joints between the main board and the perpendicularly-mounted microprocessor board. Over time vibration can cause the soldered joints between the two boards to crack and fail intermittently. 10 minutes to disassemble plus 2 minutes with a soldering iron could save you a $400 repair bill.
The service manual is available for download on the web if you google hard enough.  If you have a CRO available, the tacho waveform should be a nicely-formed sine wave with a frequency proportional to the RPM.
Mar 29, 2008 | Whirlpool AWM8143 Front Load Washer
HE4t King Size Washer Balance Problem
remove the lower acess panel ( 3 screws across bottom) check for broen suspension/shock absorbers
Mar 02, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
649 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
