Question about HP Compaq 1825 18.1" LCD Monitor
My Compaq 1825 monitor is showing pink/green instead of its usual colours. I went for dinner and came back to this.. wat do.
  • 20 Answers
R u using graphic card on ur computer??????
just check ur display cable
remove ur display display cable from ur comp as well as ur monitor n re connect it
i hope it'll work!!!
Posted on May 29, 2011
    Scholar:
  • 61 Answers
This is probably one of three problems that often screw up the colors on a monitor.
This is most likely a problem of your computer overheating. To fix this:
1. Open your computer and clear out any dust particles with a vacuum. Just make sure not to hit any of the parts of the computer and break it.
2. Get a cooling system. This could be as simple as pointing a fan at your computer and turning it on to buying a water cooling system. Just do something to try to keep your average heat lower.
This is most often the problem and will clear up your problem. If not it may be a problem of a bad cable.
1. To test this you could go out and buy a completely new cable and connect the monitor with that cable. If you don't want to pay for a new cable not knowing if that's the problem, just borrow a cable from a friend, neighbor, or your work and test with that. If it works with the new cable, buy a new one and that fixes the problem.
If neither of those solutions fix the problem it is most likely just a problem with the hardware in the monitor. If the monitor is still under warranty, contact Compaq support and have them replace it. If it is not, you'll need to buy a new monitor.
Thank you for using FixYa!
@the monitor appearance changed to pink shade and we are not able to see in this colour pl give me a solution to sent it back to normal mode
probably the color setting of the monitor has been changed.
on the monitor panel press the menu button and go to the color option.
see if increasing or decreasing the RED GREEN and BLUE color options sets back the monitor to normal.
usually some monitors have a reset option also, by selecting it everything will get back to normal.
Aug 02, 2011 | Computers & Internet
The monitor color is pink...i want it to change to normal color...
Colors on the monitor are produced by mixing the three "primary" colours.
If the monitor is not producing one of those three colours, you can get "pink" instead of "white".
Fix the monitor, or replace the monitor, or replace the video-card (if using a different monitor also produces "pink").
Jun 21, 2011 | Computers & Internet
Compaq 1825 shows pink/green instead of usual colours wat do
May 29, 2011 | HP Compaq 1825 18.1" LCD Monitor
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Hp w2007 why does the computer go pink everything that is green is now black
All the colours on the screen are created by "mixing" the 3 "primary" colours (red, blue, green).
Once the production of "green" ceases, anything that should be "100% green" becomes "100% black",
and every colour that indicates some percentage of "green" becomes a mixture of just RED and BLUE, i.e., various shades of PINK.
First, try the monitor on another computer (desktop or laptop). If the problem persists, it's time to replace the monitor. If the problem vanishes, it's the video-card in your computer that is not generating GREEN, or it is the "data" cable between your monitor and your computer that is not transmitting the GREEN request. So, you can try replacing the data-cable, or try replacing the video-card.
Jul 11, 2010 | Computers & Internet
Red colour problem in compaq 7540
Check to see whether monitor terminal has a broken pin. Otherwise change the VGA card.
Sep 07, 2009 | Compaq CV 7500 17" CRT Monitor
Pink colour
Hi there!
May be that the colour Amp is at fault or the tube is busy failing. Commonly it would be the colour Amp (Dry joints or faulty drivers). The Green is dead. I have had cases where power surge can magnetise the tube to such an extend that the whole picture will show one colour. In your case I doubt it very much. Good Luck,JUS004
Feb 26, 2008 | Bush WS6671 28" TV
HP Compaq 1825 18.1" LCD Monitor Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
