Question about Garden
I can't get the string to come out as I hit the ground with the unit
    President:
  • 3,074 Answers
Spool is either clogged or string is bound Tim
Posted on May 29, 2011
How do I design a 6 foot diameter circle for my garden?
drive a peg in the ground where you want the center of the circle to be
get a piece of string and make a loop at one enf big enough to fall over the peg
measure out 3 ft from that loop and tie a stake at that point
now pull the string until it is tight and where the peg hits the ground make a mark
move about a foot an make another mark keeping the string tight all the whole
repeat the process until you have done a complete circle
the marks will be the circumference of a 6 foot diameter circle
Oct 12, 2014 | Esschert Design USA Esschert Design...
Tip
Air Conditioner Drips and Stain Remedy
If you have ever had a dripping air conditioner. Whether the dripping sound was making it difficult to sleep or concentrate. Or maybe the dripping is making a mess on the side of your home. Splashing dirt or making rust stains on your siding. This is a remedy I always use.
Go outside the house and figure out where the drip is exiting the unit. Also, measure the distance from the place of the drip to the ground.
You will need a piece of rope or heavy string and some sort of super glue or a glue gun.
Make the rope or string long enough to be close to the ground but not touching the ground when measured from the point of the drip. Allowing the string or rope to touch the ground will give small pests an opportunity to climb into your AC and possibly your home. If you don't have rope or string an old shoe lace will work.
Glue the rope to the unit at the place of the drip, so that the water will soak into and follow the string QUIETLY and CLEANLY to the ground. I also like to tie a large fishing sinker on the end to keep the wind from displacing my string.
If you run the string into a bucket and if it is humid enough. It can quite easily provide enough water to supply flowers or a small garden. Enjoy.
on Feb 28, 2010 | Heating & Cooling
Tip
Diagnosing your small engine, string trimmer, chain saw, leaf blower, briggs...
Do you have a push mower, leaf blower, string trimmer, etc. that wont run; and you dont know which direction to go to fix it? The majority of problems are fuel related and this is a fast, easy way to determine if it is or not.
Start be removing the air filter and verifying that the choke is open ( run position). Then, spray a shot of carb cleaner ( available at any auto parts store, wal mart or dollar general) into the throat of the carb. Attempt to start the unit. If the unit hits on the prime ( starts and runs briefly on the carb cleaner) then the problem is fuel related. You should check your fuel ( water or stale), fuel lines and filter, and carb. If the unit does not hit on a prime then you should start checking your ignition system and compression.
on Dec 02, 2009 | Garden
How to fix a rx ten washburn electric guitar when it has a twang
check to see if your strings are hitting your frets. check your nut and bridge to see if there high enough to clear frets our pick ups.
Jul 06, 2017 | Music
How to feed trimmer line on y25 yard trimmer gas
Depending on what type of string head you have. If it's a "tap and go" style head, just rev it up full throttle and tap it on the ground. It should feed the string out and the blade on the shield will cut off the string to the correct length.
Sep 22, 2012 | Yard Machines Gas String Trimmer Y25
Nashville tele that has the g string sounds off when playing
if you have the adjustable bridge try moving it back a little bit. the g string is a heavy string and will tend to go sharp when you have the string height up a little. make small adjustments usually only one turn or half a turn at a time. take care to note your adjustments so you can always go back to where you started. turners are nice but the ear doesn't lie. if it sounds right it's right
Jan 19, 2012 | Fender American Deluxe Telecaster
I can't get both sides of my weedeater restring right so it can pop out when i hit i t on the ground
Make sure you are winding the string in the correct direction. Check the spool for arrows, as centrifugal force is what feeds the string out the holes.
Aug 29, 2011 | Ryobi Garden
I need to clean my capresso c1000. i can't find the instructions. i put a cleaning tablet into the ground coffee area, and ran the ground coffee button a few times. is that it?
No, first push the self clean button (hold until lights come on). Then pull the grounds unit and empty it, that will turn off one red light. Fill the water tank. Then drop the tablet. Then hit the ground coffee button. Cycle through and dump the grounds each time the grounds light illuminates.
Jul 09, 2011 | Jura Capresso C1000 Espresso & Coffee...
The weedeater string part below the Gaurd fell off I disconected the shaft and put the blower attachment on and it works fine. Is it the string head that's bad or the inside cable orthe coplete...
The part below the guard is designed to come off for cleaning and restringing, as long as you still have all the parts, you just need to put it back together and it will be fine.
Jun 30, 2011 | Garden
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
