Question about Roper REX4634KQ Electric Dryer
Dryer does not get hot it is years old lint is clean
    Brigadier General:
  • 3,301 Answers
Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 24, 2012 | Frigidaire Affinity FAQG7011KW 7.0 Cu. Ft....
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
I have an e63 error code on my dryer. It is only 1 year old and I have already had to repair my washer when it was less than 1 year old. Please help
try cleaning out the lint in you vents. Its your dryer getting too hot. u will need to replace the heater tube it this doesn't work
Nov 01, 2010 | Electrolux EIED55H Dryer
My kenmore dryer starts, gets hot,runs for 10 minutes and then stops. Could it be the thermostat?
how old is the dryer?sounds like the motor is bad,you could read out the thermostats but usually when they go the dryer will still run.alot of times i go in and the motor is covered with lint,it's like a blanket on top of the motor overheating it,people don't know that the dryer should be cleaned out,you need to blow out the vent line,clean out the duct that the lint filter slides into and vac out the inside of the dryer,i do it once a year and my dryer is 17 years old.next time send model number,i can look up your dryer and tell you how much a motor is and give you the part number,it's not that hard to change out the motor
Mar 08, 2010 | Kenmore 62602 Electric Dryer
Maytag Neptune gas dryer. Lint-free. 4-1/2 years old. Good air flow. Burner only stays on for 5 seconds. Takes forever to dry a normal load and not getting hot. Temp is on normal. Time dry or automatic. Do...
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer get to hot is simpson maxidry 505
sounds like it needs to be cleaned out,check outside to seeif the flapper is blowing open or if it is clogged with lint,if you have a leaf blower take vent line off of back of dryer and blow it out,vac inside of dryer and clean out the lint filter duct,if it's gas you should do this every year so you don't have a fire,electric every two years
Nov 08, 2009 | Dryers
I've got a fridgedaire gallery gas dryer, approx 8 years old. Takes too long to dry clothes. I've cleaned inside as best I could and the dryer duct. Is seems to get hot some of the time, but not constant
if you use fabric softener. i recommend you slow it down...alot. an appliance guys nightmare is just that. inside fabric softener, is wax. your lint screen may look clean. but run it under hot water. ive come across many a lint screen where the water will simply not go through the screen, even though it appears to be sparkly clean.
Sep 29, 2009 | Frigidaire FGQ332ES Gas Dryer
I have an Admiral dryer that is over heating. Its
bad high temp. theremostat on heater box-mike
Mar 14, 2009 | Dryers
Dryer overheating but not drying clothes!
Check the complete venting system, the lint collector may be clean, but what about the vent outside?
Sgt 48
Jun 02, 2008 | GE DBXR463EBWW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
32 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
