Question about Eliminator MotoMaster Mobile Power Inverter 700w
I purchased a 011-1871-4 1000 watt motomaster power inverter and have installed it in my motorhome. The (very poor) instructions require that a ground cable be hooked up, attaching it to the ground cable screw on the inverter. This unit does not have a ground cable screw on it. What does this mean and where would you attach this ground cable. Thanks
4 Suggested Answers
nitrospawn
  • 290 Answers
SOURCE: Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Posted on Feb 27, 2010
nitrospawn
  • 290 Answers
SOURCE: 400 watt inverter Alarm sounding
test the battery if it is still OK
al_kupchella
  • 843 Answers
SOURCE: Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
Posted on May 20, 2010
Motomaster 3000 watt inverter error display OPP what does it mean
I know a search for components on the site, and I often use it and hope to help you
www.findic.us/
http://www.findic.us/?lnk=lt
Aug 05, 2017 | Inverter Electronics - Others
MotoMaster 3000 watt inverter
Yes, it probably is a MotoMaster 3000W inverter. Whats your question???
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
My 3000 watt inverter says "lup" on the display
This question is solved in detail on a different page here on Fixya by user Pierre Curtis in detail. It's very well written. Rather than repeat, just click this link:
http://www.fixya.com/support/t26322938-3000_watt_eliminator_olp_lup_codes_any 3000 watt eliminator with OLP and LUP CODES any Ideas
Nov 09, 2013 | Eliminator MotoMaster Mobile Power...
Motomaster eliminator 600 watt power inverter wont run ps3
You need a pure sine wave inverter to run it
Jan 31, 2018 | Electronics - Others
Who makes MotoMaster power inverters? I cannot find any info on the web about this thing.
Hello D,
The Canadian Tire is selling the MotoMaster power inverters.
Please visit the link provided below :
After opening the link search for MotoMaster power inverters in search box and you will find the solution
http://www.canadiantire.ca
Oct 13, 2011 | Electronics - Others
Motomaster has two pos and neg connections for batteries cables do i need to hook up both before i can use it
I have the Motomaster 1750W. It just beeps if I try to turn it on with only one set of wires connected. When I run a pair of +/- cables from each of the connections, even to the same battery, it works find.
Oct 24, 2010 | Eliminator MotoMaster Mobile Power...
May 20, 2010 | Eliminator MotoMaster Mobile Power...
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
Eliminator MotoMaster Mobile Power Inverter 700w Logo
338 people viewed this question
Top Eliminator Electronics - Others Experts
ottworld5982
Mark Magill
Mark Magill
Tom Chichester
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
