Question about Cycling
How do I remove the Front Wheel on a Mongoose Bravo bicycle with a slotted disc brake. The disk brake hangs-up when attemping to remove the front wheel.
    Brigadier General:
  • 8,546 Answers
These types of questions are best served by search engines and yield immediate answers with video.
Google "how to remove a disc wheel"
Posted on May 30, 2011
How do you remove the front wheel of a 20" Outer Limit freestyle Mongoose bike?
if i remember correctly it is a 15 mm socket for a ratchet that is the tool that i use at the shop
Jul 10, 2011 | Freestyle Mongoose Bmx & Owners Manual -...
I need a front rim assembly for a mongoose spark 26" X1.95 dual disc brakes. i purchased this bike at wal.mart north Olmsted, Ohio 44070. the bike was hit at the front rim is bent beyond repair. i...
If you want only the rim who would assemble it for you? At this level of bicycle it's usually cheaper to buy a wheel than to buy a rim and have a shop swap it over.
Look at the disc itself and count the bolts holding it on. You want to order or locate a 26-inch disc wheel with a hub that matches the disc rotor you have because you'll be transferring it to the new wheel.
You probably also would want it to match cosmetically. Then look closely at the rear wheel and assess what brand (or at least what color) the hub and rim are.
A quick search of eBay for generic "26" disc front wheel" 's brings up 37 of them starting at $45 including shipping. OR you could drag the Bike or just the bad wheel to a real Bicycle Shop and let experts take care of everything.
Mar 23, 2011 | Cycling
How do you get the capierer pin off to put front brake pads on my Mercury Sable LS?
Section 06-03: Brakes, Front Disc 1999 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Brake Shoe and Lining Removal
  1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478) . Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
  1. Raise vehicle on hoist.
  1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120) , front disc brake rotor shield (2K004) or front wheel knuckle (3K185) .
  1. Remove rear brake pin retainers (2N386).
  1. NOTE: It is not necessary to disconnect hydraulic connections.
    Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125) . Do not pry directly against metal caliper piston or damage will occur.
  1. NOTE: To prevent damage, do not allow disc brake caliper to hang by the front brake hose (2078) .
    Position disc brake caliper out of the way.
  1. Remove inner outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate .
  1. Inspect both rotor braking surfaces. Minor scoring or buildup of lining material does not require machining or replacement of front disc brake rotor.
remove the 2 pins, #10 in pic. Usually has a dust cover over pin accessopening. Usually torx haed or hex head bolts (pins).
Nov 12, 2010 | 1999 Mercury Sable
How to take back rotors off a 1994 honda civic.
PATH: Brakes > Front Disc Brakes > Brake Disc (Rotor) > Removal & Installation Removal & Installation
  1. Raise and support the front of the vehicle on jackstands. Remove the front wheels.
  2. Remove the caliper assembly; do not let the caliper assembly hang by the brake hose, instead support it with a piece of wire looped around the front spring or control arm.
  3. Remove the retaining screw from the brake rotor and remove the rotor from the hub.
An impact driver, No. 3 phillips screwdriver bit, and a hammer may be needed to remove the retaining screw. It is fairly easy to destroy the screw slots using an ordinary phillips screwdriver to remove the tightly driven screw (see photo).
  1. To install the disc, replace the disc on the hub, screw in the retaining screw and replace the caliper assembly.
PATH: Brakes > Rear Disc Brakes > Brake Disc (Rotor) > Removal & Installation Removal & Installation
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Disconnect the caliper from the caliper bracket. Support the caliper out of the way with a length of wire. Do not allow the caliper to hang from the brake hose.
  4. Remove the caliper bracket.
  5. Remove the two 6mm screws and the brake disc. If the brake disc is difficult to remove, install two 8mm bolts into the threaded holes and tighten them evenly to prevent cocking the rotor.
  6. Install the rotor in position. Install the two 6mm retaining screws.
  7. Install the brake caliper. Install the tire and wheel assembly.
Sep 15, 2010 | 1994 Honda Civic
Adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
Aug 27, 2009 | Mongoose 20-Inch Gravity Games BMX...
I have a bad wheel bearing how do I replace it
Hub and Bearing Assembly
ani_caut.gif CAUTION: Do not begin this removal procedure unless the following parts are available:
  • A new front axle wheel hub retainer (3B477) (Step 1).
  • A new inboard halfshaft joint stub shaft circlip.
Once removed, these parts must not be reused during assembly. Their torque holding ability or retention capability is diminished during removal.
Removal
  1. Turn ignition switch to the OFF position and place the steering column in the unlock position.
  1. ani_caut.gif CAUTION: Discard the front axle wheel hub retainer. It is a torque prevailing design and cannot be reused. If loosened, the retainer must be removed and a new one installed.
    Remove and discard front axle wheel hub retainer (3B477).
  1. NOTE: Make sure steering column is in the unlocked position, and do not use a hammer to separate tie rod end (3A130) from the front wheel knuckle (3K185) . Use extreme care not to damage boot seal.
    Remove cotter pin from tie rod end stud and remove slotted nut. Discard cotter pin and nut.
  1. Using Tie Rod End Remover 211-001 (TOOL-3290-D) or equivalent and Tie Rod End Remover Adapter 211-087 (T81P-3504-W), remove tie rod end from front wheel knuckle.
  1. ani_caut.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to remove the nut, or bearing and seal damage will result. Loosen the nut first, then remove nut from stud using the hex hold feature.
    For SHO vehicles, remove vinyl cover from upper link stud.
    Remove stabilizer bar link (5K484) from front shock absorber (18124) .
  1. Remove disc brake caliper (2B120) and support with wire to obtain working space. Do not allow disc brake caliper to separate from the front disc brake caliper anchor plate (2B292) to prevent contamination of the disc brake guide pin journals. Do not allow disc brake caliper to hang from front brake hose (2078) . Remove front disc brake rotor (1125) . Remove front disc brake rotor from wheel hub (1104) by pulling it off the lug bolt (1107). If front disc brake rotor is difficult to remove from front wheel knuckle , strike front disc brake rotor sharply between lug bolt with a rubber or plastic hammer.
    If front disc brake rotor will not pull off, apply Rust Penetrant and Inhibitor D7AZ-19A501-AA or equivalent meeting Ford specification ESR-M99C56-A to inboard and outboard rotor/hub mating surfaces. Install 3-Jaw Puller 205-D027 (D80L-1013-A) or equivalent and remove front disc brake rotor by pulling on front disc brake rotor outside diameter and pushing on hub center. If excessive force is required for removal, check front disc brake rotor for lateral runout prior to installation. Refer to Section 06-00.
  1. Remove anti-lock brake sensor mounting bolt and front brake anti-lock sensor (2C204) .
  1. Remove and discard lower ball joint nut. Using Remover Adapter 211-211 (T96P-3010-A1), separate lower ball joint from front suspension lower arm (3078) .
  1. Using Rotunda Spring Compressor 014-00781 or equivalent, compress front coil spring (5310) until lower ball joint clears front suspension lower arm .
  1. Using Front Hub Remover/Replacer 204-069 (T81P-1104-C), Two Stud Adapter 205-237 (T86P-1104-A1), Metric Hub Remover Adapter 204-085 (T83P-1104-BH) and Front Hub Installer 204-067 (T81P-1104-A), press front wheel driveshaft joint (3B414) from wheel hub . Wire front wheel driveshaft joint to body to maintain a level position.
    Item Part Number Description 1 204-085 (T83P-1104-BH) Metric Hub Remover Adapter 2 204-067 (T81P-1104-A) Front Hub Replacer 3 — Turn Wrench Counterclockwise 4 — Hold Wrench Stationary While Turning Other Wrench 5 204-069 (T81P-1104-C) Front Hub Remover/Replacer 6 204-067 (T81P-1104-A)1 Two Stud Adapter A — Make Sure Metric Hub Remover Adapter 204-085 (T83P-1104-BH) is Fully Threaded onto 1107 and is Positioned Opposite the Two Stud Adapter 205-237 (T86P-1104-A1)
  1. Remove and discard three hub and bearing retainer bolts from front wheel knuckle .
  1. NOTE: Wheel hub is not pressed into front wheel knuckle . Do not use slide hammer to remove a stuck wheel hub . Do not strike back of inner bearing race. Use of these methods will damage bearing internal parts.
    NOTE: If bearing carrier is corroded to front wheel knuckle , apply Rust Penetrant and Inhibitor D7AZ-19A501-AA or equivalent meeting Ford specification ESR-M99C56-A to the inboard and outboard wheel hub/knuckle mating surface and allow to soak.
    Remove wheel hub from front wheel knuckle .
Installation
  1. NOTE: If wheel hub is damaged or if any end play is detectable, replace wheel hub . End play is not adjustable. If wheel hub is disassembled, the assembly must be replaced.
    Remove all foreign material from knuckle bearing bore for correct seating of new wheel hub.
  1. Lightly lubricate mating surfaces of bearing corner and front wheel knuckle.
  1. ani_caut.gif CAUTION: Knuckle bore must be clean enough to allow wheel hub to be completely seated by hand. Do not press or draw wheel hub into place.
    Position wheel hub in front wheel knuckle . Install three new hub and bearing retaining bolts. Tighten to 83-107 Nm (61-78 lb-ft).
  1. Push front wheel driveshaft joint into wheel hub . Hand start front wheel hub retainer.
  1. Slowly release Rotunda Spring Compressor 014-00781 or equivalent while guiding lower ball joint into front suspension lower arm .
  1. Install new lower ball joint nut. Tighten to 68-92 Nm (50-67 lb-ft).
  1. Install tie rod end into front wheel knuckle . Install new slotted nut and tighten to 47-63 Nm (35-46 lb-ft). If necessary advance nut to install a new cotter pin.
  1. ani_caut.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Install stabilizer bar link to front shock absorber . Install stabilizer bar link nut. Tighten to 77-103 Nm (57-75 lb-ft). For SHO vehicles, install stud cover.
  1. NOTE: Remove rust from the rotor and hub mating surfaces with a medium abrasive pad.
    Install front disc brake rotor and disc brake caliper . Tighten caliper anchor bracket bolts to 88-118 Nm (65-87 lb-ft).
  1. ani_caut.gif CAUTION: The front axle wheel hub retainer must be tightened to specification immediately during installation. If the retainer is not tightened immediately, the nylon lock will set incorrectly, leading to incorrect torque readings and bearing failure. Any front wheel hub retainer that is not immediately tightened to specification or is loosened must be removed and a new retainer installed.
    Install front axle wheel hub retainer . Tighten to 230-275 Nm (170-203 lb-ft).
  1. Install wheel and tire. Tighten lug nuts (1012) to 115-142 Nm (85-104 lb-ft).
  1. Lower vehicle.
  1. Pump brake pedal prior to moving vehicle to position brake linings.
May 28, 2009 | 1999 Ford Taurus
Front wheel wobbles
More than likely the wheel is out of true. There are 2 choices,
1 Buy a spoke wrench and attemp to true the wheel. You can do this by spinning the wheel to locate the spot where the wheel goes furthest to one side then tighten the spoke coming from the opposite side. Do this slowly 1/2 turn at a time. Do not over tighten the spoke. It may be necessary to loosen the other side slightly.
Alternate spokes between both sides of wobble.
2 Take bike to a good local bike shop to be tuned and have the wheels trued. Most shops offer a tune up at low cost. A well tuned bike will last a long time.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 06, 2009 | Freestyle Mongoose Bmx & Owners Manual -...
Cycling Logo
204 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
