Question about Kenmore Microwave Ovens
Kenmore elite microwave model 665.61689101 after a storm came through: 1. our under microwave lights don't work 2. microwave appears to be working but nothing heats up 3. any "sensor' heating functions give error code -F3H- 4. clock and turntable DO work
  • DWANE WALTON Jun 01, 2011
    It worked.
    Thanks!!!
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
F3H error means a failure in moisture sensor however, if you leave it unplugged for 15 minutes it should work, if won't then the sensor or the control board needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 29, 2011
How do I turn off the sound on my new Kenmore Elite microwave?
I Believe this model has an options button with codes by numbers which are 1 thru 6 I believe. Either 1 or 2 are sound. So hit the options button and hit the number 1 it should say (sound), Then you will hit 1 again a.k.a. mute, and no more beep beep beep. If 1 is not sound then you may have accidently created a small but deadly emp, so hit stop and you must hit options and then hit 2.
Dec 11, 2014 | Kenmore EM262A5E Elite Stainless Steel...
How Many cubic feet in a elite?
This is a 2.0 cu ft model. link to user manual:
http://kitchen.manualsonline.com/manuals/mfg/kenmore/721_7920.html?p=1
Sep 09, 2014 | Kenmore Elite Microwave, Model...
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
Our Kenmore microwave started emitting odors and then quit
To figure out what is wrong with it, it will have to be removed from the wall, Then the top cover will have to be removed, then you can look for any swelled capacitors, burn marks on the circuit board or any shorted wires.
The power supply is most likely faulty . You can test the power with a voltmeter from power supply to main circuit board.
Oct 28, 2009 | Microwave Ovens
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Kenmore Elite microwave Combi funtion not working
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Kenmore Microwave model 721.80019 does not heat
Hi
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. As there was power loss due to storm so I believe it could either be the the high voltage circuitry, or the circuit board . To resolve this problem, you need the assistance of a qualified appliance repair technician.
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
Jun 07, 2009 | Kenmore Microwave Ovens
Model #721.66463.500 Kenmore elite microwave hood
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 27, 2008 | Kenmore 64683 Microwave Oven
Microwave Ovens Logo
315 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
