Question about Lands Phones
Lei noticed what appeared to be a discrepancy in the time sheet of one of the customer associates. When she asked the location manager about this, she learned that the team supervisor had allowed the associate to report hours not actually worked in this pay period, thus receiving pay for time not yet earned. Lei did not like this practice and immediately viewed this as a control issue. After checking the employee handbook which had been in effect since she and Dalman were actively managing the single location, she discovered that this practice was not covered. She also realized that many of the duties that employees were expected to do and were in fact, evaluated on were also not clearly addressed. After reading the scenario above and the textbook section on Bureaucratic Control Systems, respond to the following question: Question: How can Lei apply the four step control process outlined in the text to address the problem of misreporting hours?
SOURCE: Change the Extension ID To New Employee Name
To change the names on the NEC Dterm 80.
Feature, Conf, #, 0, *, 8974, LINE 4, 18.
Select Conf to go to the name you want to change.
Select Hold to erase the characters.
Select Transfer to save it.
Once you save, make sure you go back to "18".
Posted on Apr 22, 2008
jagalbraith
  • 19 Answers
SOURCE: using function now in excel
No formula needed. Highlight the cells that you want to put the time into. These are Raw data cells. You can use other cells to calculate their times. Right click and Format Cells, choose time and the appropriate format you would like.
To insert the time click in the cell you want and do a CTRL-SHIFT-;
That is Control - Shift - Semi-Colon. This will insert the Time. Leave out the Shift and you will insert the date.
OR-----
Press Ctrl-F11
Type:
Sub GetTime()
Dim vTime as Variant
vTime = Format)Now, "hh:mm:ss am/pm")
ActiveCell.Value = vTime
End Sub
Now add the forms toolbar to your excel.
Click Button to add a button.
Choose the GetTime() Macro
Rename and resize your button.
Click in the field you want to time to go to.
Click the Time button.
Posted on Jun 10, 2008
SOURCE: customer billing
Hopefully, you already found this answer elsewhere, but just in case you're still wondering:
Customer should be the owner or member. Then, if you've made the payment "billable" as indicated in your question, you can create an invoice to that customer and use the "Add Time/Cost" function to add the billable expense.
Posted on Dec 11, 2008
ynotphone
  • 192 Answers
SOURCE: NORSTAR phone system/directory of employees
First thing, these new employees have the extensions of the old employees correct, otherwise more changes that what I gave you here will not work properly, example when you hear Press 1 it went to Joe, and Mary is where Joe used to be; that will work. But it Mary is where Steve used to be, pressing one will go where Joe was and not to Mary. Understand?
Ok, for the first part- changing the greeting in the Auto Attendant via CCR tree... you have to get into the ADMIN mailbox:
-> FEATURE 9 8 3
-> Password 1020000 (this is the default password, but can be changed)
-> OTHR
-> CCR
-> ADMIN
-> TREE 1 and press OK
-> CHNG
-> Path 0
-> REC then press PLAY to listen to the greeting, and ensure that is the one that you need to change
-> REC the new message
-> remember to SAVE! otherwise all is for not.
THIS MAY BE REQUIRED FOR OTHER TREES ex 2 or 3, listen too all trees and change if required... same steps to get into the trees and prompts.
The call forwarding to Voicemail: You need to know how to manuver around programming via the template on your phone:
-> press FEATURE 9 8 5 to get the DN of voicemail
-> FEATURE * * 2 6 6 3 4 4 (**CONFIG)
-> password: 2 6 6 3 4 4
->TERMINALS&SETS and Enter
-> type in extension that you want to change and Enter
-> next to CAPABILITIES and Enter
-> FWD NO ANSWER and Enter and put in the DN of the voicemail
-> hit NEXT and then RLS and voila, you are done!
Posted on Apr 07, 2009
label_chick
  • 407 Answers
SOURCE: How to sende information from a sheet to another?
You can link to the original sheet or copy and paste - Linking might be easier as you only have 10. - Can you not use worksheets rather than excel. If you want to make it more autonomous you can index or look up the first sheet so any changes you make will be reflected back in your employee sheets.
Posted on Jun 04, 2009
Butterick pattern 6771. Where can I get instruction sheet?
About the only thing to do is purchase another of the same pattern.
Dec 21, 2015 | Crafts & Hobbies
Screen is locked and nothing is working...
Hi Kris A Hemenway-Sheets, Condolence to your family. I just want to ask if the phone is Android, what version is it? If its 4.4 and below, enter a wrong pattern or PIN five times. You'll see a "Forgot pattern," "forgot PIN," or "forgot password" button appear. Tap it. You'll be prompted to enter the username and password of the Google account associated with your Android device.
Nov 06, 2015 | Samsung Galaxy Cell Phones
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Jan 05, 2015 | Cannon Office Equipment & Supplies
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
  9. Check the printed pattern
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
  15. Check the printed pattern
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
Hi I wanted to adjust the clutch 883 of my iron, I opened the cards came out transmission oil, not having consulted the service manual I thought it was engine oil is doing to change that after closing the...
If your bike is a 2010 model, you can use the same oil in both areas, the engine and transmission. If you are in doubt, simply drain the oil in both places and put the correct amount and kind of oil back it. No Problem. Italian, I hope.
Lei non sbaglia dovrebbe causare alcun problema poiché il modella tardi le marche di Harley di motocycles usano lo stesso olio nel motore e la trasmissione. Se lei è riguardato, cambia semplicemente l'olio in entrambe le aree. Non credo che lei avrà alcun problema. Spero questi lavori di programma di traduzione.
Buono Steve di Fortuna
Jul 15, 2011 | 2010 Harley Davidson Sportster XL 883N...
I purchased a nikon coolpix camera a few months back, when purchasing i was asked if i wanted the plan, i asked what it covered and the associate said everything, i told him my 2 year old broke the last...
Well, I would take the Nikon Coolpix camera back to the retailer that sold it to you and ask to talk to the manager about this discrepancy.
Apparently, it says in the fine print that when you purchase a Nikon camera, and it is dropped, that the extended warranty doesn't cover this.
I would tell the retailer that the associate told you that 'EVERYTHING' was covered and you were under the impression that it covered dropping it as well.
I would tell the retailer that you will report them to the Better Business Bureau for misleading statements by a salesperson and see what the manager tells you after that.
It's true that extended warranty plans cover normal wear and tear items, and not abuse or misuse as indicated by dropping it accidentally or getting it wet in the rain, but I would ask the higher ups at the retailer about the warranty being honored since you paid for it.
I hope this helps you out.
Oct 29, 2010 | Cameras
Maxtor mini one touch 4
When you were in device manager did you notice if it was enabled? Did you try to force install the hardware somewhere else, or did you try to change what driver was used?
Ryan Frame
Creative Energy Associates Technical Center
Aug 24, 2009 | Seagate 80GB One Touch 4 Mini-maxtor USB...
Customer billing
Nov 04, 2008 | Intuit QuickBooks Pro 2007 Full Version...
Cannot reset the change drum soon message after replacing drum.
This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
This message would continue to appear if the clear plastic starter sheet was removed from the "new" drum before it was installed. This plastic starter sheet, resets the drum counter. To reinstall drum with the starter sheet, please follow the instructions listed below:
Locate the starter sheet. Clear plastic sheet, 9 inches long, with a cut out in the center. The sheet will have "Initialization of your new drum successfully completed. Please discard this sheet" written on it.
If you cannot locate the starter sheet, contact the Brother Customer Service or the appropriate Brother authorized dealer.
additionl info HERE
Jul 11, 2008 | Brother MFC 4800 All-In-One Laser Printer
Lands Phones Logo
381 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
