Question about Univex 250 Watts SRM12 Stand Mixer
Univex # 1222 mixer
I would like to know what meat grinder attatchments will fit my mixer and the numbers are ?
bigg t
  • 640 Answers
SOURCE: Univex mixers
Im not bias on my opinion,but from the repairs i do on mixers hobart mixers are far superior than other manufactures.Hobart is over 100 yr old company that started with mixers and their service dept. is good.unlike any mixer out on the market they mirror off of hobart.
Posted on Nov 30, 2007
  • 25 Answers
SOURCE: KitchenAid Mixer
depending on the model there is a round cover on the front of the mixer. Detach it to expose the secondary drive connection. Depending on what you are connecting to it you need to connect to the drive port and secure the accessory so it is stable. If you need instructions google kitchen aid and ask them for a manual.
Posted on Mar 26, 2008
  • 12 Answers
SOURCE: the pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Posted on Mar 16, 2009
SOURCE: Black Residue on meat using Kitchenaid meat grinder attachment
the guy that said that the meat produces this is full of it since the black reside is the blade friction against the round metal piece with the holes, i had black fine powder all over my mixer without any meat
Posted on Jul 19, 2009
SOURCE: I have a Kitchenetics K-11 mixer with a meat
You can buy parts for your machine here:
http://www.mykitchencenter.com/Details.cfm?ProdID=1359
You may have to call them and inquire as to the specific part you need - they also have used parts that they sell.
HTH!
Posted on Aug 21, 2009
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Need instrucion manual for moulinex electric meat grinder & salad maker
You don't mention what model number, but you might try this page. It has several meat grinder instructions booklets you can download.
http://www.moulinex.com/Pages/default.aspx
Jul 22, 2014 | Food Mixers
I was using meat grinder attachment and stand mixer stopped running
I just got the same problem too. There was a little piece of fat in the meat and it stopped the grinder. I removed it but the attachment rotates a full turn and then stops. The same happens with other attachments even under practically no load.
Dec 02, 2010 | KitchenAid Food Mixers
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The pasta/meat grinder attachment stops turning
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Put kitcheraid meat grinder back together
Proper assembly of the Food Grinder Attachment is covered in the attachment's Use and Care Guide.
Jan 11, 2009 | KitchenAid Food Mixers
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
Univex mixers
Nov 29, 2007 | Univex 250 Watts SRM12 Stand Mixer
Univex 250 Watts SRM12 Stand Mixer Logo
315 people viewed this question
Top Univex Food Mixers Experts
Oscar Netto
Oscar Netto
Are you an Univex Food Mixer Expert? Answer questions, earn points and help others
