Question about Abit AN52 Motherboard
I cannot get the video slot to work with any video board, 16x pci or the 1x slots
  • joecoolvette
    joecoolvette May 29, 2011
    What is the name and model number of the graphics card?
    Master:
  • 328 Answers
Should be helpful
enjoy your time sirI cannot get the video slot to work with any video - khaled_h_1.jpgkhaled_h.jpg
Posted on May 29, 2011
Hello,I can't connect this card to PCIex16 female J41
You can't use that card in a PCI express slot because that specific video card uses an AGP connector (which is no longer a supported card interface). You will need to use a motherboard that has an AGP slot.
Feb 13, 2015 | Nvidia model-p118 - Model P118 Geforce4...
How to add a card
open the case up then pull a slot out of the case then put it in put screw in card slot then power up then put in drivers for card
Aug 13, 2014 | Computers & Internet
Fitting a Gforce video card in a veriton 5700GX
Your restrictions are based on available slot size and version. So get one that fits PCI-e x16.
Could not locate PCI version so check your manual, because the slots are backward compatible. Meaning you can connect a Ver 1 card into a Ver 3 slot, but not the other way around.
Expansion Slots - 1x PCI-e x16 slot, 1x PCI-e x1, 2 x PCI slots
Dec 11, 2012 | Computers & Internet
Are pci and pci-e cards the same
No the cards are not the same. One has 62 pins on each side of the card (minus a cutout for a key with the slot) and the other has 32 pins (PCIe 16x) or fewer. They have different power requirements and won't fit directly in the other slot. There are adapters for PCI-e 1x cards to use them in a PCI slot and adapters to put a PCI card in a PCI-e 1x slot. See any of the component vendors for details.
Make sure to order a card that will fit in your computer's slots. It will save you trying to determine if the card, slot or adapter has failed.
I hope this helps.
Oct 27, 2011 | Lenovo IBM ThinkCentre A30 8199 (8199XX2)...
How to install Pci-e 16x in a pci slot
Do not put a PCI-e card in a PCI slot. It will not fit and the card won't work. The PCI card has 58 or 60 pins on each side with the slot (62 pins would be present if not for the key notches for alignment). PCIe 16x cards have 32 pins.
There are adapters to put a PCI card in a PCIe 1x slot (will fit any PCIe slot) or a PCIe1x card in a PCI slot. See http://www.amfeltec.com/index.php for a sample of the adapters. For the PCIe 16x cards, you need a new motherboard.
If you are placing a PCI-e 16x card in a PCIe 16x slot or a PCI card in a PCI slot, then open the side of your case. Locate the matching slot (remove the current card) or an empty slot depending on your motherboard. Depending on the case, you may need to remove a screw to remove the old card. Wiggle the card straight up to remove it. If you are putting in a new card, you will need to remove the cover from the slot. (For some larger PCIe 16x cards, you need to remove the adjacent slot cover as well.) Some covers just pull straight up or pry a lever up and then pull; for others, you will need to use a screwdriver to break the cover out. Make sure there is sufficient room near the slot for the card. (You may need to move other cards around.)
Then line up the card so that the back of the card will fit into the opening and the contacts on the bottom of the card are above the center of the slot. Firmly press the card down into the slot without changing the alignment. You may need to wiggle it (press down on the back and front, alternatingly). Then make sure the card is fully seated. Attach the addtional power cord from your power supply, if needed for a PCIe 16x card.
Close your case. Then if this is a new video card, turn on the computer and enter the BIOS (press F1, F2, F10, Esc depending on the machine). Disable the on-board video. Then reboot the computer and load the drivers you need for the card.
I hope this helps.
Oct 16, 2011 | Computers & Internet
What are the basic parts of the intel motherboard?
cpu, video card.hard drive, floppy drive cpu fan, power supply, is the battery good first for cmos, are all the connection right. is the power supply good.is the mem.right in the slots is it ddr or ddr2 do you have the right speed on cpu for board as well as mem , what is the intel board numbers on it d915 or what i need to know which board to find out anymore ok jim
Jul 04, 2011 | Intel Motherboard
I have the Board ASUS P5VDC-MX. And I wonder that there is no pci-e slot, but in the information there is written:"this board is pci-e (16x) ready".... is it right ? Can i use a pci-e (16x) video...
No, you can't use a PCIe x16 card in any of the slots on the P5VDC-MX board. A PCIe x16 card can't fit into the PCIe x1 slot. Attempting to force a PCIe x16 card into the PCIe X1 slot will break the card or bend the pins. A PCIe x1 card will work in a PCIe x4, x8 or x16 slot, though. Similarly, the AGP and PCI slots are not compatible with the PCIe x16 card design.
I wish that I had better news for you.
Aug 19, 2017 | ASUS P5VDC-MX (P5VDCMXGREEN) Motherboard
Upgrade
moz-screenshot-3.jpgmoz-screenshot-4.jpgIt appears that there are two PCI Express slots on the MB, 1-1X and 1-16X. You should be able to put in a PCI Express video card. If you are going to be gaming, pick out one with more memory, but be prepared. More memory equals more money.
Good luck and let me know how it works out.
Feb 20, 2009 | Intel D101GGC Motherboard
Fastest pci slot?
Hi stevebise, no not at all. The 2 white PCI slots on the P5LD2-VM run at the standard PCI 2.2 speed. Which is 32 bit at 33.33MHz or 133MBs. How ever your board has another PCIE port which is double the speed of a standard PCI port. This is what a PCIE 1x nic card looks like;
http://www.provantage.com/startech-st1000btpex~7STRN021.htm See page 1-22 in your manual.
If your current network card seems to function in the white PCI slot as a (KillerNic), than why buy a PCI 1x nic. As they say, "Ain't broke, don't fix it".
Hope this answers your question.
Mike
Sep 13, 2008 | ASUS P5LD2-VM Motherboard
Video card for the gateway 507gr
Yes, your computer specifically supports:
PCI Express 16x and
PCI Express 1x
The 16x is the long one and the 1x is the reallly short one. Most likely the card that you get will fit the big slot. Be careful not to upgrade too high though, because if you do you may have to upgrade your power supply as well. Ask someone at gateway or a local shop for a recommended card for your system.
Apr 23, 2008 | Gateway 507GR PC Desktop
Abit AN52  Motherboard Logo
46 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
