Question about Coleman Powermate Proforce 2500 Generator
I have a coleman 2500 gas generator when I try to start it on choke after I prime it. It starts and runs for about 5 sec and then stops. I replaced the old gas with new gas any ideas?
    President:
  • 3,074 Answers
Sounds like the carburetor got gummed up with gas being left in it over the winter/not being used in a few months. You may have to take it apart and clean it up with carburetor cleaner, possible the needle and float may have to be replaced, good luck Tim
Posted on May 29, 2011
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
The generator will not start. When I spray Gumout into the carborator, the engine runs for about 2 to 3 seconds then shuts off no matter what position the choke is in. Please advise.
hi, carefully remove the bowl from the carb and clean out any water/rust/dirt etc allow fuel to pass through the carb till it drips out , reattach bowl and leave it for 10 mins then try starting it .
hope this helps
Apr 26, 2010 | Coleman Powermate Proforce 2500 Generator
I tried to start my new coleman powermate 6250/5000,
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Apr 24, 2010 | Coleman Powermate Premium Plus 6250W...
Starts runs a few seconds and stops until primed again.
Make sure the fuel shut off valve is opened and retry - Not the problem?
Next, take the bottom of the fuel bowl off and clean carb and bowl with carb parts cleaner - wait until dry and re-assemble.
HTH, if so please indicate so
Mike...
Nov 24, 2009 | Coleman Powermate Proforce 2500 Generator
I have a coleman powermate generator 5000 in from 2006. Has never been started. I tried to start, filled the oil/gasoline and It would not start. What can I do beside's taking it in for service.
Remove the air cleaner and spray some starting fluid into the carb. If it starts then ok if not then remove the spark plug and check for spark.
Keep posting until its fixed. Give the model number PMxxxxxx.
Jul 27, 2009 | Coleman Powermate Powermate 5000W...
It starts fine and runs on choke but not off choke
It sounds like you are not getting enough gas. I think it's the diaphragm, When you take it off of the choke diaphragm controls the gas flow, apparently yours is just shutting down. It's very inexpensive, and very easy to replace. Good Luck :)
Feb 23, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Coleman Powermate Proforce 2500 Generator Logo
421 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
