Question about Refrigerators
GE Profile Refrigerator-PFSF6PKXEWW - refrigerator temperature light keeps blinking.
  • 5,370 Answers
Check the doors, if any of the refrigerator door is not getting closed or remaining bit open, then inside compartment will get bit warm and temp display will blink.If that is not the case then other possibility is fan in the freezer section is not working or its got clogged by the over frost ice collected beside the fan blades and this warms the fridge section.And due to this temp light blinks.So check the fan movement, if its not running, then its the cause of problem.If fan is running, then it can be the issue with temp settings, in that case the temp setting in both the compartments needs to be checked.Either its set too high or too low.Re check and re-set the temperature settings.If that is no the case then its faulty part.the temperature controller and thermostat are to be checked and replaced.this parts are causing the problem.
You can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site. ------- Click this link for more help:--- http://technoanswers.blogspot.com/2011/05/refrigerator-temperature-light-blinking.html --------- ---------This will help.Thanks.Helpmech.
Posted on May 29, 2011
GE Profile pss27sgrss has a bad main pc board
Yes I would agree that you get another refrigerator! The GE PSS27SGRSS is an Artic/Profile model and people have had nothing but complaints about the motherboard problems. I recommend you buy something that has no motherboard or electronic defrost. The best refrigerators out there are ones that have the simple defrost timer and no electronics, Thanks Sea Breeze
Dec 05, 2012 | GE PSS27SGRSS Side by Side Refrigerator
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE PSC23MGNA refrigerator. No display light for
Sounds like you have a bad main control board . The original pt # is WR55X10552 . The replacement board is WR55X10656 . Your original board , is on a recall list , and GE should come out and replace under an extended warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Oct 31, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Unplug it for around 30 mins. then plug it back in and see what happens. Try this before anything.
Dec 26, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
207 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
