I have an LG model LSN306hv duckless split. The AC will not do anything but show CH 24 on the unit in the building. What does CH 24 mean? I tried changing everything on the hand held controller but nothing helps. It still shows CH 24?
SOURCE: error ch 5
check all wiring and connections - ch 5 is a communication error between the indoor unit and the outdoor unit......
Posted on Dec 16, 2007
  • 95 Answers
SOURCE: i installed a dual split
Post a little more information and by the way are you certified to handle freon? $10,000 fine if you are not.
Posted on Jun 10, 2008
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
  • 81 Answers
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Posted on Jul 20, 2009
  • 53 Answers
SOURCE: What does CH 24 mean
Ch24 means your unit has a low or high pressure fault,check gas charge and if filters are clean see if helps
Posted on Sep 01, 2011
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Oct 15, 2016 | LG Art Cool LA181CNW Split System Air...
What does Fault code ch 26 on lg inverter split system mean?
Get the model number from under the indoor unit and I'll try help you out
Sep 02, 2014 | Heating & Cooling
What does CH 24 mean on ArtCool mini-split?
Aug 31, 2011 | LG Art Cool LA121CNP wall/window Air...
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
LHD65EBL Code CH 01
I had the same problem, and I wound up calling LG's customer support line. The rep I spoke with says that the "CH" code means that the internal thermostat is not able to accurately read the air temperature, and the unit will require servicing.
She gave me a couple of numbers for local folks, and I'll call them in the next day or so, but I'm thinking that this may not be worth the repair, unless it's pretty cheap: I bought the unit for under $100 less than 9 months ago, and I'm not eager to shell out a bunch of money to get it repaired.
Nov 02, 2008 | LG LHD65EBL Dehumidifier
We have an LG SQ/SR/ST chassis inverter model air conditioner....the airconditioner keeps stopping with the screen display...C6 appearing. When we turn it off at the mains it seems to reboot it for a while...
i can figure out what model a/c you have from this discription/ is this a lg floor mod. or window model or lg duckless split system
one comon problem causing faut is dirty filter or condensor but hard to figure if i cant place the unit disciption.
Oct 20, 2008 | LG Heating & Cooling
I installed a dual split ac system an code ch 33 comes up on both units does this mean its low on charge? i put in the recommended freon
Jun 09, 2008 | LG Heating & Cooling
Error ch 5
Dec 09, 2007 | LG LSC183VMA Split System Air Conditioner
Lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Jun 13, 2007 | LG LS240CE Split System Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
