Question about General Electric AEH18DL Air Conditioner
NEED A schematic FOR A GE AC WINDOW UNIT MODEL AEH18DLG1
Need schematic for GE model jkp86sh5ss
look inside the unit behind the top rear cover somewhere GE always puts a mini-manual inside their units which will have a schematic specific to that machine.
Jan 11, 2015 | GE Ovens
Can someone provide a wiring schematics for a GE Refrigerator model TCC18JAAC type LB18,
Look on the bottom under the kick panel usually the schematic is located there enclosed in a plastic pouch or it is taped on the rear of the unit. If not try repairclinic.com
Jul 29, 2014 | GE Refrigerators
Window AC unit, Hi speed doesn't work. AC motor
It is possible that the high speed went out on the motor but I doubt that. I would replace the switch and see if that takes care of your problem.Good luck and thank you
May 25, 2011 | GE Heating & Cooling
My ac went out in my house my cousin let me use a window unit. i place it on a stand in not out the window can i do that or will it get to hot in on the back grille the unit is a ge /model number is...
Hi, yes it will get even hotter as the rear condenser coil has to be vented outside to cool. This is where and how the unit gives off heat. Whats the problem with your home a/c? I can help you there also.
Sincerely,
Shastalaker7, A/C, Contractor
Aug 19, 2010 | GE Heating & Cooling
My blower on my GE combo heater/ac oil fired won't come on auto.
I am assuming that the red button is you safety switch, there should be a schematic on the door panel of the unit.
Jul 17, 2010 | 2004 Ford F150
GE model AJM10DFV1 window unit I need the
remove front panel and there is an info plate that says:
Cool BTU/ HR AHAM 9 700 / 9 500
AHAM - Association of Home Appliance Manufacturers
May 06, 2010 | GE Heating & Cooling
Have a ge ac in window unit asto5 model leaks inside just recently . connot find any plug to pull for draining outside excess water inside ac cabnit . does it have one? been running this ac all summer and...
No drain plug but this model should have a SLINGER RING AROUND the end of the fan blades which picks up the water & sling it on the back coil which it is so hot & evaporates to help get rid of excess water .. So as for the water running inside, the drain channel are plugging up, from the front coil to the back, & only need to add clorox bleach to the front coil area for now , to kill the slime or mold slowly blocking the channels..But first, TURN_OFF UNIT! (certain times of the year, mold & slime grows rapidily and thats what the bleach for..!
Sep 05, 2008 | GE Heating & Cooling
General Electric AEH18DL Air Conditioner Logo
162 people viewed this question
Top General Electric Heating & Cooling Experts
Donni Steen
Bill Long
AJMAL KHAN
Are you a General Electric Heating and Cooling Expert? Answer questions, earn points and help others
