Question about RCA MM52110 52" Rear Projection HDTV-Ready Television
Hello. My 52 inch RCA projection TV model no. MM-52100 bought probably in year 2000- from Circuit City. Chasis MMC102A. Original problem was TV looked 3D. I think this problem is called convergence? It would "straighten up" if I turned the TV off then on. Now when I turn the TV on, it turns off- then the green link blinks 3 times. TV does not turn on at all. Thank you so very much!
    Top Expert:
  • RCA Master
  • 39,260 Answers
The power supply could be failing.
Posted on Aug 13, 2017
techman
  • 3130 Answers
SOURCE: rca 52' projection convergence problem
Its a good possibility that your convergence problem could for now be cold solder connections on the driver ICs on the convergence board. The longer you use it the more of a problem its going to surge those ICs till they go bad and maybe cause other componet falure as well. If your not a technician i would have this set serviced asap before it becomes a major repair Good Luck
Posted on May 22, 2006
  • 1694 Answers
SOURCE: 52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Posted on Apr 15, 2008
Slinteriors
  • 8617 Answers
SOURCE: problem with convergence
you dont need new CRTs (tubes) you need either the convergence Board or the convergence power supply board depending on the symptoms. If its only one color that is out of alignment its most likely the convergence board. If all the colors are out of alignment you need the convergence power supply board. you can get whichever one you need at the following link as they have both of those circuit boards and have free shipping. Heres the link,
http://servicemanuals.vstore.ca/
Posted on Jun 22, 2008
leethedeuce
  • 4472 Answers
SOURCE: R C A 52" Rear Proj. TV
https://www.manualsparadise.com/MainSearch.do?brand=429&model=MM-52100&elementChanged=Find
You can find the service manual to answer all your questions usually for around 25$
If you need any other assistance please let me know.
Thanks,
Lee
Posted on Sep 12, 2008
SOURCE: 52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Posted on Nov 05, 2008
36" RCA Proscan TV no picture
LINE ACROSS THE MIDDLE IS THE VERTICLE CIRCUIT--COULD BE A LOOSE CONNECTION-TRY TO TAP GENTLY ON TOP OF SET AND SEE IF YOU SEE THE PICTURE ACTUALLY JUMP TO FULL RASTER,,IF SO LOOSE CONNECTIONS IN VERTICLE CIRCUIT---THE OTHER PROBLEMS WOULD BE ACTUALLY PARTS BAD IN CIRCUIT --IC,CAPS ETC... TUNICA
Oct 21, 2008 | RCA P52926 52" Rear Projection Television
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52 inch tv will not come on and has no sound
you can get your TVs deflection board remanufactured at the following link for alot less than that shop is saying and they guarantee the board for 6 full months.
Aug 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Do we need a new TV?
I dont think this problem can be fixed without solder work or part replacement of convergence section. Its no just matter of fuse. You should get repair facility from concern service center because TV has dangrous voltages inside and qualified person knows how to deal with TV.
Jul 23, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA model P52927
Look, take out back cover and on the bottom left and right side you will see screw (2 or 4), take out it,Disconnect 2 plugs wire from chasis, pull out the box and you will have space for clean your screen.( You will take out all box with main chasis, convergence chasis )
Apr 22, 2008 | RCA P52926 52" Rear Projection Television
RCA MM52110 52" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
