Question about Mitsubishi WS-55411 55" Rear Projection Television
It is fuzzy when it first comes on and then just not as clear as it was before. can i open the back and clean it or will that make a difference?
  • 28 Answers
Cleaning won't help unless you have reason to believe it's unbelievably filthy inside, which is generally not the case. Plus cleaning the screen and/or lenses may make things worse if you aren't experienced. Many sets have a "magic" or auto focus procedure they can run on themselves to calibrate themselves periodically. Check your Owner's manual if possible, or look for a button that says something like "focus". This process takes several minutes, do not interupt it once started... good luck.
Posted on May 30, 2011
Fuzzy screen with lines on desktop computer
Dear Debbie,
Greetings from New Zealand! Try a different monitor & see if fault still exists...If not the monitor, then could be fault in box...either hardware or software....(???maybe interference from other devices in home/nearby???) Your may need to install/replace video card - if you have one? (I THINK that if it is a fault in the all-in-one motherboard type of video that a separate "PCI" video card MAY solve it?) I hope that these suggestions help?! 'b'ye - Bruce.
Dec 28, 2013 | eMachines Computers & Internet
Fuzzy picture
Try moving the hdmi cable around, disconnect it and reconnect it. Try using a different video source.
Oct 20, 2012 | Hannspree Televison & Video
My Sanyo DP42647 TV has sound but comes in very fuzzy not clear at all
have you checked it on video inputs on rear of set and also on tuner inputs to see if problem on all inputs?
Aug 26, 2012 | Sanyo 42 in. LCD TV
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Hello Two days ago web images and logos on this PC/monitor started becoming fuzzy/pixelated. Also, web pages load slowly. Problem is seen with different browsers also. Desktop environment appearance is OK....
1)Go to Control Panel>Appearance and themes>display>settings>Make sure your screen resolution is set to more than 1024X768 and millions of colors.
You didn't download an accelerator for a modem, did you? If so, that is usually how the accelerator works, by deducting pixels from graphics. If that is the case, go to your accelerator and choose use original image settings. The other place we need to look is in browser settings and internet connections. See pics below. Make sure that compression settings are not too high.
2) clear your cache, cookies, and history.Instructions differ, but go to control panel>network settings>internet options. You can also check on your internet connection.
Lastly, if you have been making graphics for the web with Adobe, or another web program, make sure that you haven't changed your view settings in an effort to conserve memory in your editing programs. Sorry if I gave you redundant advice, I couldn't find your first post. Thanks, please continue to leave comments if your situation changes.
Text and graphics are totally different, so browse through you internet settings to make sure that you didn't accidentally changed something. You can choose reset original tools/option settings in browsers and Adobe if you are not sure where the problem comes from.
Nov 19, 2009 | Computers & Internet
Brand new fax when we send a fax it is received at the other end fuzzy or blurry. Tried a different phone line and still the same. Cleaned glass on scanner
Slight possibility that your sending in Photo Mode, most likely the machine was damaged during shipping and the CCD unit or scanner is out of alignment. Just make a copy....if it comes out blurry then it is the scanner. I would return it for another machine. If the copy comes out nice and clear then there is nothing wrong with the scanner.
Oct 22, 2009 | Brother IntelliFax-4100e Fax
The screen is not coming in clear anymore. All of
get it to a profesional he will set it inside if the DVD...he will probably open the dvd up and adjust it from there...please dont do this alone because i am avere of the dangers at this...
Aug 25, 2009 | Philips DVDR3575H/37
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
I've had my HP Photosmart 8250 printer for 2 years. All of a sudden the pictures are not as clear--a bit fuzzy. What can I do to try to fix it?
1, power on
2, open the cover
3, push cartridge all the way left
4, clean up cartridge seat at right hand side in the machine with water
5, you may find a clear plastic strip across behind the cross bar that is a sensor clean it up
Dec 13, 2008 | HP Office Equipment & Supplies
Mitsubishi WS-55411 55" Rear Projection Television Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
