Question about Fedders AEJ12E7AG Air Conditioner
How many BTU's does model AEJ12E7AG have? - Fedders AEJ12E7AG Air Conditioner
    President:
  • 3,072 Answers
Ronnie,
You have 12000 BTU/Hr Cooling and 10000 BTU/Hr Heating
Tim
Posted on May 29, 2011
How many BTU's are in each element of a 1990 model hardwick propane stove?
Hello, it will depend on the size of the burner. If you have two large burners, one medium, and one small burner. It will also depend if you are using NG. Now, with LPG, it would be about 10 % less than natural gas. I am take a guess here, OK. Large burners 5000 BTU's. Medium: 2500 BTU's, and the small maybe 1200 BTU's per hour. Now, most of the burner on newer stove/ranges are set by the industrial standards. GB...stewbison
Sep 04, 2011 | Kitchen Ranges
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
How do I find out how many "tons" my Carrier AC units are?
Look in the model number for numbers like 24, 30, 48, or 60....
They represent the BTU's in thousands of the unit....
The BTU's are 12,000 per ton...
in other words a 24000 BTU unit will be a 2 ton unit
heatman101
Jul 29, 2011 | Carrier Heating & Cooling
How many BTU's is this model?
By the Model Number, it's 10,000 Btu's , Norma.
Jul 13, 2011 | Maytag M6Q10F2A Air Conditioner
How many btu's does kenmore model # 580.72056 have
About 5400 BTU's, approx large enough to cool a 12x12 area without overtaxing the AC unit.
Jul 03, 2011 | Kitchen Ranges
I have a Fedders A6X08F2A-B Service # and Serial # MP 178550 and I would like to have the specs on it eg: how many BTU's, model # etc
Hi, The numbers you have given tell me, this unit is a 8,000 btu unit.!2, 000 btu's equal a ton of cooling, so you are just under a ton. This is about all I can tell you. There should be a data plate that will give you amps, volts, compressor amps ect.
Shastalaker7
A/C, Contractor
Jun 10, 2011 | Fedders X Chassis A6X08F2A Air Conditioner
Unable to locate the drainage for condensed water. I could look inside and see that water is accumulating at the bottom. Feddlers AEJ12E7AG, window unit. Thank you
Hello, most window units evaporate the condensate by having the fan blad sling the water on the condenser. Because the condenser is warm/hot it will evaporate. You shou.d be hearing a sloshing sound after the unit has benn running for a while, this indicates that the fan blade is picking up the water from the bottum of the ac.
May 31, 2011 | Fedders AEJ12E7AG Air Conditioner
Whirlpool window a/c model: acm152xlo How do I find out how many BTU's this unit has
That model number indicates a nominal capacity of 15,00 BTU, so it should be within 500 BTU on either side of that
Hope that helps
May 11, 2011 | Heating & Cooling
Open Questions:
See all Fedders AEJ12E7AG Air Conditioner Questions
Fedders AEJ12E7AG Air Conditioner Logo
168 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Tony Pez
Level 1 Expert
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
