Question about Amana ABB1922FEW (186 cu ft) Bottom Freezer Refrigerator
We are looking to replace the defrost thermostat in our Amana, where can I get this part?
    Sergeant:
    Champion:
  • 207 Answers
Go to Sears's website and you will find that they have parts for just about any appliance. www.sears.com. Then go to the parts store on the site.
Posted on May 29, 2011
5 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: freezer fan is on constantly, replaced heater and thermostat, could it be the defrost timer and where is it located?
There is a control board located on some models. I will give you the link below you can call and ask where and how because the prints are not very helpful. Thanks, Sea Breeze
click link below
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=9307
Posted on Apr 29, 2009
  • 1218 Answers
SOURCE: My Amana ABB2524HEW quit defrosting. I have
Good day,
If the machine has been running at least 6 hours in cooling mode, and the thermostat shows open. It is defective, and needs replaced.
It is located in the freezer section behind the back panel, and is located on the top of the cooling coil.
Hope that helps.
Thanks for using FixYa
Posted on Jan 25, 2010
  • 949 Answers
SOURCE: amana bottom refrigerator bx20rw, how do i replace
This link will show an exploded view of the area. Part number 6 is the defrost thermostat. Cut and paste into your browser.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=273&diagram_id=810195#d810195
Basically you need to empty the freezer, remove the drawer and back panel, unclip the thermostat and replace, there are two wires and should be the same on the new one, use caution not to damage the evaporator coils.
Posted on Apr 18, 2010
ZJLimited
  • 17970 Answers
SOURCE: I have an amana abc2037des.
In both cases it was the defrost timer, an electric clock switch that turns the defrost on & off. On these, you can check this by manually advancing the timer until it goes into defrost. On my ~8 year old Amana, the timer can be advanced at a recessed screwdriver-slotted red knob on the ceiling of the frig portion just behind the panel with the temp controls. If yours has this, advance the knob & see if the defrost turns on (you can tell because the switch clicks and if the compressor is running at the time, it shuts off).
Easy and cheap to replace, if that's the problem. Also if the thing's iced up you can defrost it a couple times this way and get air moving again until you can replace the part.
Other guess could not thermostat. That doesn't control defrost. First check for power on the defrost heater. If none then check deforst timer for power in. If present then change defrost timer. That is where power comes from to the heater. If power then bad heater.
Thermostat controls the compressor. When the temp inside goes up the thermostat turns on the compressor to cool the fridge or freezer. Here's the diagram. It looks like if the thermostat is "open", the heater won't run...
Also, in thius links, can check info...
- applianceaid.com/defrost_cycle.html
- applianceaid.com/frig_notcold.html#ff
Hope helps.
Posted on Sep 10, 2010
Fridge and freezer both not cooling
Yes , your fridge can get stuck in defrost mode. If you can locate the thermostat. Sometimes buried behind a panel in the freezer. There's an adjustment screw or trim screw that allows you to advance the timer on the thermostat. Sometimes they stick in the defrost mode. It may happen once and never happen again. If however it does continue you will have to replace that part.
Oct 28, 2017 | Amana Refrigerators
Amana ARSE66MBW not going into defrost cycle. I'm
you should read around 25 ohms on your defrost heater if it cks good, you should read 0 ohms on your bimetal if its encased in ice, if your bimetal reads 0 ohms and the heater reads good ohms then replace your defrost control. lmk if u need more help
Aug 03, 2013 | Amana ARS2464BW Side by Side Refrigerator
I have an Amana ARB8057CSR that has stopped cooling. I have replaced the capacitor and overload relay on the compressor as well as the defrost thermostat and eliment. When plugged in it sounds like th
Part of your message was missing but I do see that you did not mention the defrost thermostat=> 12001937 Defrost Thermostat
Chec for any loose wire or burned electrical connections and remember that the defrost thermostat is designed to be on while below freezing temperatures and once the temperaytures reach 50 degrees F the contacts in the defrost thermostat open to prevent the freezer from getting stuck in the defrost cycle for too long and also is a safety feature. Test the defrost thermostat with a OHM Meter while freezing.. Ask if you need I will be here to answer any questions you may have, rate if helpful and please ask if you need more answers, Thanks John Tripp/ AKA Sea Breeze
Possible Causes
Symtoms: Frost or ice on evaporator
1. Defrost thermostat faulty->Check defrost thermostat. Replace if failed.
2. Evaporator fan faulty ->Check fan motor. Replace if failed.
3. Defrost control faulty ->Check control and replace if failed.
4. Defrost heater remains open -> Check defrost heater continuity.Replace if failed.
5. Open wire or connector -> Check wiring and connections. Repair as necessary
6. Refrigerant shortage or restriction -> Refrigerant shortage or restriction. This will look very differen that a totally frosted over evaporator. Click here for what that looks like=> Lack of Freon
Nov 09, 2011 | Amana ARB8057CSR Bottom Freezer...
I cant locate the defrost timer on my amana AFD2535FES. my freezer is cold but the fridge isn't
That model refrig. does not use older style parts sorry their is no defrost timer. What is uses is a control board to turn on the defrost cycle. Before replacing the defrost control board check the defrost heater and thermostat first. Check both defrost heater and defrost thermostat first using a meter to check continuty on both of them. If either the defrost heater or t-stat dont hav econtinuty they will be the problem. If both check good the control should be replaced. These pictures show where the defrost heater and thermostat are while or model will look different the location of them will be very similar RMOSTAT IT MUST BE COLD SO CHECK IT WHILE FROST IS BUILT UP AROUND IT.oldtech2332_11.jpgoldtech2332_12.jpg
Aug 16, 2011 | Refrigerators
Top half of both fridge and freezer appears to have stopped working.
Your defrost heater or defrost thermostat may be bad. Test defrost heating element for continuity. If heater is good, replace the defrost thermostat. In most cases, replacing both is advisable.
Dec 17, 2010 | Amana ASD2622HRQ Side by Side Refrigerator
Amana warm fridge - broken defrost - even forced defrost broken
Did you also check the defrost thermostat? That may be the only part you missed. Any time I change a defrost heater I make a simple habit of replacing the defrost thermostat. Sea Breeze
Dec 16, 2009 | Refrigerators
Hi there i have a client with an amana frigde sxd524ve fault is very ic ed up evap unit no fan running i defrosted unit and resarted system fan now running i believe defrost element and or timer may be...
Okay, rookie ;)
Amana fridges have problem with the defrost thermostat, which you may not notice without looking at the thermostat very closely. If the plastic cover on the thermostat is swollen or is higher on one side - replace the thermostat. Fan in these fridges is connected in series with the heater and the defrost thermostat.
... And finally 127 Ohms for a 110v heating element is too high, resistance must be lower. If you measure it through the defrost thermostat - separate them and check again.
Oct 14, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana refrig model ARB8057cc. Freezer is icing up and not cooling well
Looks like the defrost thermostat is bonkers. Plan to replace.
Aug 19, 2009 | Amana Refrigerators
I need to know where to find the defrost timer on my amana fridge. this is the 22.6 cu. ft model #sqd26vw. Ive looked in the back and found the compressor but no defrost timer. specifically is it in the...
remove the grill at the bottom of the fridge there is a black box wth a knob sticking out you can turn in only one direction clockwise till you hear a click and the compressor and fan will cut off if running.
Jun 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana ABB1922FEW (186 cu ft) Bottom Freezer Refrigerator Logo
89 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
