Question about Stanton T62 Turntable
I think I have burned my turntable, a voltage problem. does it have an internal fuse? what should I do? thanks
  • 670 Answers
Burned your turntable. do u mean burnt out the motor. my suggestion is to take it to where ever you bought it explain it to them have there techs look at it and go from there.
Posted on May 31, 2011
2 Suggested Answers
SOURCE: Turntables voltage been changed now wont turn on
have you switched the voltage switch over underneath the turntable plate
Posted on Aug 16, 2008
I have a Stanton turntable, model T52. I think that the internal fuse or the transformer has blown. How do I check to see if it is the transformer or the fuse or both? There is no power getting to the
I cannot view any more information in your initial post after
There is no power getting to the except that you think the fuse is intact. From my experience, there is no transformer driving the turntable motor since these operate directly from the power mains. Can you show us a picture? Dave
Dec 21, 2014 | Stanton T.50 Turntable
Replaced the touchpad and put it all back together. It now heats, but the oven light doesn't come on and the turntable doesn't rotate. Do you think there's a loose wire?
First check is the main fuse of the unit. On countertopunits, you will need to take the shell off. The fuse will be close to where thecord comes through into the unit. OTR units, this main fuse is usually behindthe control panel or possibly behind the vent. Usually the fuse is obvious ifblown, otherwise test with an OHM meter, if open, replace fuse. Some brands will also have a thermal cut-off fuse in theincoming voltage line to the control board. This thermostat looking fuse isusually above the oven cavity somewhere under the outside shell. Sometimes youcan get to it through the vent of OTR models. Test with an OHM meter, replaceif open. Forturntable: First, make sure the turntable coupler under the glass dish is notbroken. Second, on the control board, find the turntable relay and test forvoltage. Some turntable motors are 24 volts DC, so make sure you're testing thecorrect voltage. If no voltage from the control board, then replace the controlboard. Otherwise head towards the turntable motor. On OTR models, you can get to the motor by un-screwing thebottom panel on the microwave. On countertop models, there will either be aknockout or screw on access panel. Check for voltage at the motor. If novoltage, check the wiring back towards the control. If voltage, then replacethe turntable motor. Hope this will help you. Good Luck.
Sep 03, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
No power past what I think is the transformer? My gauge indicates there is power in the main power cord. Thank you.
Can you test to see if power is coming out of the transformer thing? If it's not it could have failed. Some transformer have an internal fuse. Unfortunately these are generally not replaceable so the transformer has to be replaced. Transformers are also safety parts, so have to be replaced by manufacturer's replacement parts.
Jan 31, 2011 | Crosley CR-84 Turntable
I bought two numark ttx usb turntables of ebay with no warranty, they were from the usa. one of the turntables works fine the other did not even turn on at all. i thought it must be that i did't flivk the...
Here is a copy paste from Numark's Quick start owner manual page 3:
3. Voltage Selector:
This switches the internal voltage transformer between 115V, 230V and 240V. The turntable should be shipped with the proper voltage setting for your region. Check that the switch is in the proper voltage before connecting the power cord to prevent damage to the turntable.
At page 2 also there is a diagram showing the exact place for that switch.
So I can't believe that this turntable is stricted for use under 115V. Also, as far as I know from my experience (23 years Electronics Engineer), the only thing that coulg be before the transformer is either the voltage selector switch, or some kind of ac filter. The only case that I'm not sure, is the case that you powered up the turntable at a 230V area and the Numark's voltage selector was set at 115V. In that case the transformer should be burned and the service should replace it and charge you the cost for that.
I think that there is something strange at your case. Why don't you check at another service center at your area?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 13, 2010 | Numark TTX1 Turntable
Technics SL-1200MK5 voltage or fuse problem
To change it from the 110 to 220 the switch is under the turntable platter. Put your fingers in the 2 holes under the slip matts and pull up evenly. It may be a little hard but it will come off. As for the fuse...its inside the deck. Unscrew the feet and all the screws. the black rubber part will come off. Good luck!
Dec 17, 2009 | Technics SL-1200MK5 Turntable
I pluged my american stanton T60X (125V) to 225V. Any solution?
if you can find a fuse or reset switch, replace/reset that first. look around where the power cable enters the device.
if it has no fuse, you've probably cooked the transformer which converts outlet voltage (mains) to whatever the voltage the device is designed to run on. if that's the case, then you'll just need to swap in a transformer that matches the requirements of the deck to the output voltage of whatever country you want to use it in.
if this sounds too daunting and you're not confident with taking electrical stuff apart, go to a shop and get them to sort it for you.
long and short, don't ditch your deck just yet, Chet.
Apr 05, 2009 | Stanton ST-150 Turntable
Aug 14, 2008 | Technics SL-1210 Turntable
Internal fuse
remove platter remove plastic cover main fuse is there
Jan 29, 2008 | Technics SL-1210 Turntable
Blown Fuse
The fuses for this model are located underneath the turntable platter. You can replace this yourself, however, please be sure to disconnect the unit from it's power source before proceeding. You will have to remove the metal turntable platter, exposing a black protective cover. Remove the cover, and you'll see the main PC Board. There are 2 fuses on the lower left side. Pull the fuses and take them to your local electronics store, or order online @ www.1200s.com. IF your unit does NOT have any fuses, then your transformer is damaged, and will need to be replaced by a qualified technician. Also, the fuses are only meant to circumvent small changes in electrical current. Many times, these voltage surges, will fry the fuses and the transformer. So if after you replace the fuses, it still doesn't power up, you will need to also have the transformer replaced. Good Luck!
Sep 14, 2007 | Technics SL-1200MK5 Turntable
Stanton T62 Turntable Logo
146 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
