Question about Whirlpool Washing Machines
Repair Manual GHW9400Pl1 Error code F06 - Whirlpool Washing Machines
    Brigadier General:
  • 3,301 Answers
F/06 error code, Drive Motor Tachometer Error. I checked the manual which states to check wire harness, check drive motor, check MCU. Checked wire harness from motor to MCU and MCU to CCU.
Posted on May 29, 2011
My Whirlpool Duet is showing error codes f06 and e02 and wont unlock door or run cycle, what can I do?
Janice,
Here is a link to a website that gives the F06 code, but I cannot find the other code.
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.
Scroll down towards the bottom to find the Duet fault codes.
Jul 28, 2015 | Whirlpool WFW94HEX Duet 5.0 cu. ft. Front...
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
What does Error code F06 mean
Try this:
Possible Causes / Procedure1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Read more: http://forum.appliancepartspros.com/washer-repair/11384-front-load-maytag-what-error-code-f06.html#ixzz33vFGkt1n
Apr 23, 2014 | Maytag Dryers
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool AWM8143 sixth sense
Try replacing the brushes this may solve the problem
Jul 03, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
146 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
