Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
The engine starts and then shuts down in 10 seconds.
    President:
  • 3,074 Answers
Fuel issue, check lines from tank to primer for cracks, check primer bulb, and carburetor. Tim
Posted on May 29, 2011
Ford tractor
How old is the fuel in the tractor? is it petrol or diesel powered?
Apr 14, 2014 | Cars & Trucks
Passlock dont starter
The Passlock system is notorious for failing. There are 3 different parts of this system that can shut down the car and activate the Antitheft security system. The problem will be one of these 3 things. The key. the ignition lock cylinder, or the TDM. The easiest one is the key. The key will either have a small black chip in the key shaft or a transponder hidden in the key head. If there is a chip, they are known for wearing down and not reading correctly. Try wiggling it, cleaning the chip with alcohol, and taking all other keys off the key chain because it pulls on the key and causes problems. If you have no chip and instead a transponded key, (it will have a little "+" sign by the plastic) you can try performing a relearn procedure. It goes like this.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
If that doesnt work, you will need to start replacing parts. Like i said, there are 3 parts. The key, the ignition lock cylinder, and the Theft Deterrent Module (TDM). all of these are involved in the Passlock system and could be responsible for shutting down the vehicle. And trust me they are all expensive. I always share this link for this problem because there is so much information on there and will be helpful no matter what you decide to do. If all else fails, there is PERMANENT FIX for this problem. You can bypass all aspects of the system and never worry again. That is also on this link.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 19, 2011 | 1997 Oldsmobile Achieva
How to rekey a pontiac sunfire 2004
Im assuming you are refering to the anti theft security key relearn process.
If that doesnt work, look into this link http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 07, 2011 | 2004 Pontiac Sunfire
Programing a key fob
If this doesnt work, you may have a failure in your system. If the security light is on, and the reprogram doesnt work, you might want to look into bypassing that antitheft system.
Aug 06, 2011 | Oldsmobile Alero Cars & Trucks
How to reprogram key
If this doesnt work, and you are having STARTING issues, go to this link.
Jul 29, 2011 | 2005 Pontiac Grand Prix
My 50 cc dirt bike is messed up will start but won't runbutabout 10 seconds the engine bogs up then shuts down
Hi and welcome to FixYa,
Initially, determine the quantity and quality of the fuel by loosening the drain screw and catching the fuel draining. Additionally, determine if there is spark right after "engine bogs up then shuts down".
The "quantity and quality of the fuel" would be indicative if the fuel is contaminated and/or if there is sufficient fuel in the carb's bowl to run the engine above 10 seconds. Checking for the presence / absence of spark after the engine quits would help you determine if it is an electrical problem or a fuel starvation issue.
Good luck and thank you for asking FixYa.
Nov 08, 2009 | Suzuki Boulevard S50 Motorcycles
Car starts but shuts off
Replace the crank sensor. This happen to me
Sep 05, 2009 | 1999 Chrysler Sebring
Cranks but won't start
Jus the motor shut off? Or did all the gagues, lights, everything seem to shut down? If all the gagues acted up, sounds like the ignition switch, not the lock cylinder, the acutal ignition switch.
Sep 14, 2008 | 1991 Chevrolet S-10 Blazer
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
193 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
