Question about Black & Decker Garden
Lawnmower Model MM675. Took the blade off to sharpen it. Nut, metal washers[?] blade came off at once. Not sure of the correct way to reassemble the components. Is there a diagram available showing how the parts go back? Thank you.
    President:
  • 3,074 Answers
The blade goes on first, then the washer and the nut, Tim
Posted on May 29, 2011
Have had blades sharpened and have reassembled and it appears to work -blades move etc -but won't cut
first check your belt to be sure it is on the pullys, next check to be sure the blades are locked on the spindle and tightened. It should work. good luck
Nov 22, 2015 | Garden
Procedure for removing spindle blades for sharpening
The blades on the spindle do not require sharpening. It is the single blade at the base of the lawnmower that requires sharpening.
Feb 09, 2015 | Garden
How do I sharpen a lawnmower blade
You have to take the blade off of the mower by taking the center bolt out and if there are other bolts beside the center bolt they also have to come out.
I use a bench grinder to sharpen all of mine and when you put it back on make sure you put it on the right way. Not upside down.Making sure the center bolt is tight but don't strip it. You have to hold the blade when taking it off and if it's too tight I put a block or vice grips on the blade and body so it don't slip.
Jul 09, 2014 | Briggs & Stratton Briggs Stratton...
Flymo tines
What are you referring to as tines, it sounds like you are working on a roto-tiller. I will need more info as well. Model# Unit type-ie. lawnmower. Are talking about the blades? If so the there is a large nut that bolts the blade to the lawnmower. Remove bolt by holding blade with gloved hand and long breaker bar. You can strike the breaker bar with a three pound hand sledge to break it loose. Replace or sharpen blade as necessary. Apply grease or never-seize ti threads on crankshaft, spin on the bolt and tighten with long breaker bar. Good luck!!!!! If this is a tiller, then let us know, ok?
Mar 26, 2014 | Garden
I have a florabest electric lawnmower, the blades are turning and were sharpened recently but it is not cutting the grass...any ideas?
check that the blades were put on correctly and the sharp side is in the right position . if not then the blades are trying to cut the grass on the back side un sharpened side.
Jun 02, 2013 | Garden
Elect mower blade replacement
mower, then blade, then plastic part, then metal square washer, then nut
Apr 23, 2010 | Black & Decker Garden
Lawnmower lbade assembly sequence
1. install round washer first flat side facing you.
2. round plastic washer next flat side facing the washer.
3. next step blade.
4. next step square plastic washer label facing you.
5. then the square metal washer, make it flash with the shaft flat side.
6. tighten nut by hand at first then use impact tool if you have.
Jun 08, 2008 | Black & Decker 19" Electric Lawnhog...
Black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
80 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
