Trying to remove a broken piece of plastic from the fan. it is making this irritating noise when it is running
  • 20 Answers
Take a picture of that and repost ur problem.
Posted on May 29, 2011
IDYLIS model 416709 portable air conditioner. How can I remove the back?
On some air conditioners of the type you describe, attaching hardware is removed from the rear to allow removal from the front.
Jun 03, 2015 | Heating & Cooling
When i turn my heater on it sounds like a leaf ,piece of paper,like a fan blade is off balance the higher the speed the louder the noise also makes same noise on ac
could be exactly that a piece of paper if its not too irritating i wouldn't worry. if you can clarify where it comes from i may be able to be of more help.
Apr 22, 2012 | Kia Sportage Cars & Trucks
Hi My bissell proheat 2x 9500 is making a loud noise when the brushes are moving. I replace both belts and cleaned the brushes. Can you think of anything else it could be.
Hello there,
Try using other brush attachments, as broken bearings in a brush attachment will cause noise. If these troubleshooting techniques do not work, you may need to service the engine.
Remove the filter and bag of the machine and make sure that they are not clogged or full of debris. Clean any filters according to the instructions for your model or replace the bag. Excessive debris will make the engine run noisily.
Inspect the hose of the vacuum and remove any large debris that may be clogging the inside of the tube. Large amounts of dust, as well as stones or other hard materials that bounce, may cause a loud noise in the engine.
Remove the housing that conceals the engine of your machine and inspect the fan for damage or clogging. Remove any dirt or debris that may hinder the movement of the fan. Inspect the fan for any damage such as bent or excessively sharp blades. Replace the fan blades as needed; contact your vacuum manufacturer if the fan is damaged. The replacement part will include instructions.
Tighten the fan with a ratchet if it is loose on the assembly. A loose fan will make a rattling sound as the motor revs.
Wipe dirt and dust from the frame of the engine. Large quantities of dirt or dust around the motor can cause it to overheat, which can cause vibration and loud noise.
Look for corrosion around the engine. If the engine is corroded, it must be replaced.
Grease the bearings of the engine if you hear a grinding noise from the vacuum. Greasing is often performed through ports in the engine, or by removing the bearings. However, the actual greasing method is model-specific. Consult your owner's manual or send the vacuum to a service professional for this service.
Inspect the inside of the vacuum cleaner for other worn parts or broken pieces. Worn or broken pieces can cause loud noises to occur. Remove the broken part and order new materials from the vacuum manufacturer or take the machine in for service.
Hope this information was helpful to you. All the best. Elect_Comp
Sep 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
The fan is making a "scratching" noise.
Hi steffmarin...
The scratching noise is one of two problems.
1.noisy fan bearings, cannot be lubricated, must be replaced (big job), or replace fan....
2. Plastic/rubber bearing up near the ceiling...the fan will be connected to it.
Sometimes when they get dry they get noisy.
You can spray the plastic/rubber bearing with a little WD-40 and it will hold the noise quite for a while...be sure to "wiggle" the fan around after spraying to distribute the WD-40) evenly.
If your noise problem is this then problem solved.
Please take time to rate me
Jul 22, 2011 | Hampton Bay 52 In. Ceiling Fan, San Tropez
My xbox 360 is making clicking noises, vibrates alot, and is extreamly loude while running, i think its the fan in it but im not sure, so what should i do?
Hi Charles
There are several reasons your console is noise , First remove your game and
listen and see if the noise is reduced also the vibration should stop too.
I have seen or heard rather this before . The cause was a the drive spindle
hub some how got skew so the disk wobbled as it was spinning.
The fix was simply to replace the hub/spindel motor .
The rattling sound may be from the tilt switch or pieces of plastic
bouncing around . you will have to open your console to remove the
the small chunks of plastic + blowing it out will help cooling also.
The fan should not make that much noise . If it seems to be loud
then you may need to replace the heat sink compound on the G.P.U.
and the C.P.U.
if you have any questions feel free to ask.
Rob
Mar 31, 2011 | Microsoft Xbox 360 Console
Why does the Fan make louder noises when you run certain programs, and is there a way to prevent it from making these loud sounds?
If this has Smart fan technology on the mobo, it will do this as the fan speed is increasing to compensate for the increase in the temperature of the CPU.
You could , if the noise irritates you, purchase a better cooler, one with copper heatpipes and a larger fan..
Jan 03, 2011 | HP (219115001) CPU Heatsink & Fan
F16 error occurs when trying to switch on DVD Home Cinema System
F16? I've seen F61. Usually an output IC problem, but it can be caused by a bad fan.
Remove the fan. Remove the sticker from the fan. Remove the small round piece of plastic (if it has one) from under the sticker. Put a couple of drops of oil or wd40 it it and spin the fan blades several times. Replace piece of plastic and sticker. Re-install the fan. Good Luck.
Feb 10, 2010 | Panasonic Home Theater System System
Refrigerator runs way too much.
make sure it is level. the compressor is designed to run on level ground. also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise. find out where the noise is loudest. if it's under the fridge, it's the compressor. if it's inside the freezer, it's the fan.
Aug 28, 2009 | Refrigerators
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Model # 795.75286.402 Motor running load
The evap fan motor most likely is running loud due to a ice build up around the fan and the fan blade is hitting it and making a loud , irriting noise. Shut the ref off. If you are mechanical, remove the draw and the back cover, clear out the ice. Also, the ice may have been caused because the sensors-- thermistors--- are not located properly. look at the ceiling of the freezer and you see a small holder piece. the part is located there. tahke the cover off and take the thermistor that may be buried in the ceiling and pull it down and locate it in the holder, reinstall the holder. Not also, there is another one in the ref section to do the same thing
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
