Question about Fisher and Paykel DEGX2 Dryer
Heating element not putting out much heat and periodically pops the internal breaker. When it is working, it takes 3 times the normal amount of time to dry a load.
    President:
  • 3,074 Answers
Restricted air flow, disconnect vent tube dry a load of clothes. You can use a leaf blower or a shop vacuum to blow out vent tube, Tim
Posted on May 29, 2011
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Oct 02, 2012 | Dishwashers
Tip
How to clean the inside of your coffeemaker
When coffeemakers2_bing.gif make only a few cups of coffee instead of the whole pot, it's usually because the heating element is covered with hard water deposits. To fix it, you just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
The cause of the slow brewing is that the water you normally use has some amount of hardness to it, and over time the hard water minerals build up on the heating element inside the machine. The buildup prevents the heating element from heating the water as fast as designed. The vinegar will dissolve the minerals and let the heater work at full capacity again.
If you want to avoid this in the future, just run the white vinegar through it once a month or so even if it's not running slow.
on Jan 31, 2010 | Cuisinart DCC-1200 Coffee Maker
Tip
What to do when your coffeemaker stops after just a few cups
When coffeemakers make only a few cups of coffee instead of the whole pot, it's usually because the heating element is covered with hard water deposits. To fix it, you just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
on Jan 31, 2010 | Coffee Makers & Espresso Machines
My dryer will only work for like 3 minutes and then it kicks out the breaker. It is an lg tromm dle3777w. It has worked fine for about 4 years. Used it for a load already today and it worked fine. ...
Hi - there is a fault with the heating circuit, most likely either a bad connection on the elements or elsewhere on the wiring. The only other problem would be the actual heater element, although doubtful as it would normally pop the circuit breaker instantly if this was the case.
Although i'm not familiar with this particular model all dryers operate the same way, when on air dry there is usually no heating involved, it will work ok.
If you can handle the repairs yourself otherwise get an electrician or appliance serviceman to help you out.
Jun 15, 2011 | Dryers
My Dimplex DFB 4047 won't get very hot
This is an on going problem with electric fireplace/stove type heaters of all types. Not just Dimplex.
They are not designed to run for long periods of time and the heat output is not much more than a blower dryer. In any event, they take in cool air, heat it and send it back out. Over time, the heating element becomes clogged with dust, lint and/or pet air. So, they have to work harder to produce a sufficient amount of heat. Cleaning the heating element with a vacuum that has a hose and brush attachment may help. The heating element and blower are under the stove. See your Owners Manual on how to access it. Be sure to unplug the stove before trying to service/clean it.
Feb 05, 2011 | Dimplex Compact Electric Flame Stove...
Hi, my dryer runs for about 5 min. then it pops the circut breaker. never did this before.
You either have an exposed wire shorting out in the dryer or the breaker itself is weak.
Try running it on air only or low heat to see if it still trips in the same amount of time. Also if the unit heats up on air only setting you have a grounded element.
Depending on the type of heating element you have, sometimes they loosen up, as it heats up it sags and touches the case/chassis tripping the breaker.
The above is not 100% because if you have a loose wire you could be removing power to this part of the circuit when you switch to low heat.
If it is the element often you can see the burn mark on the case.
Dec 28, 2010 | Estate TEDX640JQ Electric Dryer
My hamilton beach brew stations quits after brewing 2 cups of coffee.... we have to turn it off and turn it back on several times to get the whole pot brewed. help.
You just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
Jan 31, 2010 | Hamilton Beach BrewStation 47224 Coffee...
Heating element is going out it work about ten percent of the time? need parts number and ways to get parts. and is it the actual heating element or something smaller electrical since it is intermitent ?
It may be your heating elements, but I would check your circuit breaker to make sure its putting out 110V on each phase as the heating elements are the only part in your dryer that use 220V, so if the circuit breaker is not outputing enough voltage that could be your problem (it's also a less labor intensive fix). NOTE: IF YOU ARE GOING TO REPLACE YOUR CIRCUIT BREAKER TURN OFF THE MAIN BREAKER TO HOUSE TO POWER DOWN THE BUSS BAR THAT THE BREAKER IS PLUGGED INTO.
Nov 03, 2009 | Kenmore 84072 Electric Dryer
I have a Frigidaire self cleaning electric oven. I heard a two pops and this tripped the circuit breaker. I can't reset the circuit breaker because the pops occur again and trip the breaker again. Any...
Sounds like a shorted wire or something grounding.
Slide out range and unplug and take off bake and look around for a short either at the bake or broil element ot at the terminal where the cord connects.
Oct 01, 2009 | Kitchen Ranges
Gas dryer
Welcome jessegonzales
Check the outside vent leaving your house does not have a screen on it.
Take the screen off. Even half blocked and the dryer will not dry well.
Possible solutions
1. Defective Heating Element
The heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
The normal method for checking a heating element is to check it continuity. With the element unplugged you can check the continuity from one wire post to the next. If the circuit is open, thent he heating element is faulty.
However keep in mind that the element could be shorted to the case as described above. In this situation it is possible to have continuity, but the element still be the source of the problem.
Let me know.
Please remember to leave a rating
2. Defective Heating ElementThe heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
the heating element is faulty.
3.Defective Thermostat
The thermostats are responsible for maintaining the proper temperature in the dryer. Check the exhaust temperature of the dyer and if the temperature is above 150 degrees, you will most likely need to change the operating thermostat.
The thermostat can also fail in the opposite mode. It can prevent the element from heating at all. A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw. These thermostats are often used to control the timer when set to the Automatic Dry cycle. If the dryer timer will advance in the Timed Dry cycle but not the Automatic Dry cycle, then the thermostat could be the problem.
4. Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
One of these will solve the problem!
Thank You
Huuum.
Jul 29, 2008 | Frigidaire FGQ332ES Gas Dryer
Fisher and Paykel DEGX2 Dryer Logo
164 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
