Question about Ridgid Drills
I have the 12 volt lithium drill. The small one and I was working on a roof when I placed the drill in a gutter with water in it. OOPS! The water got into the motor part. Now when I press the trigger, it does nothing exspt the little lite flashes on and off. Did I fry it out? do you sell replacement parts? This is the best drill I've owned. What do I do now? Sandy Banks
    President:
  • 3,074 Answers
You will need to take the drill apart and inspect to see if a connection burnt, if not then try another battery, Tim
Posted on May 29, 2011
How do I charge a string of say 10 x 18650 Lithium batteries?
Can get a 4 gang charger on eBay, ~ $20.
If they're wired in series, (nominal 37 volts) will need a DC power supply capable of 40-50 volts DC. Limit the charge current to 1-2 amps with a series resistor or a small 115 volt light bulb..
Feb 12, 2015 | Drills
Ryobi manuals
YOU CAN GO TO GOOGLE AND DOWN LOAD THE MANUEL.JUST TYPE IN INSTRUCTION MANUEL ROYOBI CORDLESS DRILL 1048-67479CS LITHIUM BATATERY CB 120L YOU SHOULD BE ABLE TO DOWNLOAD THE MANUEL
Aug 12, 2014 | Ryobi Ridgid 12V Cordless Flashlight 12...
Makita BHP452ZW light works but no drill power
Your most likely problem is the switch (PN 650583-6). When they go bad they will let power go to the LED light but it won't get to the motor. With a multi-meter, check the power going into the switch and coming out to the motor. If 18 volts are getting through to the motor then you may have armature (PN 619198-8) issues.
Nov 26, 2013 | Makita BDF452HW 18V Cordless Lxt Lithium...
How do gutter guards work?
they work like a screen, letting water into the gutter but holding leaves and solid objects outside of it. this allows the water inside the gutters to flow freely without being blocked by these objects
Jan 15, 2013 | Roofing
Can we use the new 18 volt litheum batttery on the old 18 volt drill
Are you asking if it will fit, or if it will work, or it it is safe?
I can't tell you if it will fit, or even if it will work, but I can tell you this--- If it fits, then go ahead and try. It won't hurt anything, but they may have put the contacts in different places, so it might not work. But do not try to charge a lithium battery on an old charger.
Jun 25, 2010 | Dewalt 18 Volt Compact Drill Kit
My ryobi 12 volt drill fell into swimming pool yesterday. i let it dry and drill works with different lithium battery but other battery wont charge. is it junk?
You may still have moisture in the battery that fell in the pool.
Try heating the battery real warm with a hair dryer. In an effort to remove any internal moisture. This is a "nothing to lose idea". Then put it in the charger.
Feb 15, 2010 | Drills
Where are the drain holes & how to unblock them in a clio sunroof
hi from uk the sunroof water drain holes are situated within the gutter below the sn roof surround seal and are both at each rear corner/s of sunroof to un blocktry a length of wire preferably plastic coated and poke the wire and twist as you push in drain tubes then use a small water can as u would use for indoor plants and pour hot water gently into the gutter if main blockage has disturbed ? hot water will/should flush the drain tubes thro you could also continue poking with wire too ? i use a length of wire from house lighting 1;0 mm" use either live or neutral wires (insulated) this always works for me TIP! when you wash car raise sunroof and clean gutter channel with rag to prevent dust collection blocking holes/drains in future
Nov 29, 2009 | 2000 Renault 181
How do i re-assemble a makita 18v cordless drill
check out ereplacementparts.com and type in your model eg bhp451 they should have an exploded diagram.
Dec 21, 2008 | Makita 12 Volt Cordless Drill/Driver Kit
Drills Logo
54 people viewed this question
Top Ridgid Drills Experts
Tim Whalen
Bill Boyd
Are you a Ridgid Drill Expert? Answer questions, earn points and help others
