Question about Whirlpool Dishwashers
Whirlpool DU1145 won't start. Tried the test mode
  • 7 more comments
  • mbarber292 May 29, 2011
    I'll try the reset. The door latching properly and continuity on the door switch wouldn't seem to be an issue since it will run through a complete test cycle... implying neither one of those are not operating properly, but I could be wrong.
    No luck. Guess, I need to tear it down to get to the door switch. Any pointers?
  • mbarber292 May 30, 2011
    ok, easy enough. I checked the switches both are working fine (used a multimeter and checked both open and closed state of switches). I restored power to the unit and then closed the switches and the system came on like it was doing a drain. After verifying the switches I checked the buttons on the front panel... same symptoms. The Start button does not respond, but the other buttons do. I'm beginning to think its the logic board, but, I've never worked on these so I have no idea. If you have a schematic, could you feed me some test points and readings (in a former life I was an electrician).
    I don't seem to be communicating very well. The only button NOT working is the Start button. I can press other buttons and get some lights to come on. However, I cannot start a cycle. Pressing the Start button does nothing. This means I get no glowing lights when power is applied. I'll do whatever I need to. I think the question comes down to either the CCU is broke or what situation would cause the Start button to stop responding. Before I start pulling the unit out I'd like to see how to test (hopefully at the CCU) if the float switch or other remote switches are working. There does not seem to be any water in the unit. I can hear the float switch when I manually actuate the float, so it isn't stuck. I'm not sure what other sensors exist and which ones would deactivate the Start button.
    While I haven't fixed it yet. The details in this response are what I feel I need to resolve the issue.
    Thanks.
    excellent. will do. thanks.
    Jackpot.. found the schematic. Thanks.
    Last question I hope...
    There is a troubleshooting step on the sheet. "Checking keypad operation" - the results are as follows
    "If the control is OK, it will respond by turning on a Drain Motor for 2 minutes. Check and/or replace the keypad if the control responds OK"
    Can I get just a keypad?
    No worries. I understood. The best price I've found so far is about $208.. ugh. Still better to know. I've been to that site, a little on the high side compared to what I've found. Thanks for the help.
  • Whirlpool Master
  • 19,396 Answers
Hi.
The light flashing it is not an error code. The dishwasher tries to drain because you press the pause button. When you press pause, if there is water Cancel/Drain glows, the dishwasher pauses for about 5 seconds and starts a 2-minute drain . When the dishwasher drains all the water the light goes off. If the light stays on, then the dishwasher cannot drain either because of a problem with drain system or because of a defective control board.
If the appliance does not even start cycling, there is noise, and there is water inside the appliance, then the problem is drain/overflow. If there is no water, start checking from the overfill switch.
If the dishwasher bottom looks dry either there is water trapped in the corners or in the bottom panel, or the drain hose is set incorrectly, and water is flowing back from the drain line, triggering the overflow device. If there is no water and drain hose is fine you will check the overfill device for faults.
Pull out the dishwasher and check the drain hose height and elbow. Ensure that settings are as specified in the user manual. If elbow height is incorrect you get water flowing back from drain inside the dishwasher. That is detected as overfill.
Remove the drain hose and put it in a bucket, then try tilting the dishwasher 45 degrees backward, secure it safely (ask help if needed) and start cycle, so that water trapped at the bottom can be released. Put the drain hose to correct settings and put back the appliance in place if this solves the problem.
If that does not help, then parts must be tested.
Check the drain well again.Open the housing, and remove water present in there . The overfill switch is connected to the float and can also be responsible of the problem. The switch itself can be tested jumping its contacts or using a multimeter to read Ohms at switch contacts. With contacts jumped no overfill will be detected and machine will start working (stop cycle manually after machine begins filling).
If that does not help, go for the rest. Do not replace parts without testing. Check again inlet hose, check spray arms and impeller. Next step would be reading volts from CCU (central control module), and eventually replacing the control module
Test first the drain system, which is the possible culprit.
Disconnect power before performing any maintenance operation.
Regards.
Ginko
Posted on May 30, 2011
  • 2 more comments
  • Ginko
    Ginko May 30, 2011
    Hi. The start button is a switch integrated in the button board. If the machine starts and performs the diagnostic cycle OK, then the problem is the button board or the connector in control board. The diagnostic cycle use the same relay to startup the cycle (the relay is one of those three black boxes at one side of the board). Only the buttons used to start are different, hence problem is either button switch or soldering/connector on main board.
    The fascia panel is over $200. Before replacing it test parts. First test the connector coming from fascia panel.
    First test the button. Button configuration in connector is not listed in service manual. At the bottom an extract from a different service document covering different Whirlpool models. Try the different configurations. Put multimeter on Ohms. If a button is good the two contacts corresponding to the button must open and close (pass from infinity to zero) when you press the button. If the table does not apply to your module, keep on button pressed and find out which two pins in connector read zero. Those correspond to the button.
    If you find that button is opening and closing, then test one by one the solder joints on control board connector located at the opposite side of the relays. Set the multimeter on impedance. For each pin on control board ensure that contact is not open (infinity of Ohms) between control board pin and solder joint on the other side.
    Click on the picture to open, if necessary click again on browser picture to enlarge more:
  • Ginko
    Ginko May 30, 2011
    I wanted to add to check behind the toe panel to see if there is a technical sheet in a sealed envelope.
  • Ginko
    Ginko May 30, 2011
    Hi.
    Sorry I was online.
    As I said the keypad is probably what you need to replace. The keypad is integrated with the panel and is an expensive part, usually over $200. To find parts and diagrams select the complete model number from the list on this website. If your model is not listed, select Home in the part website, and enter your model number in the box.
    All the best.
    Ginko
  • Ginko
    Ginko May 30, 2011
    I wanted to add a clarification on parts name:
    1 Part is the fascia panel with button. That is the keypad or control panel.
    1 Part is the plastic box with inside the control board. That is the control module or CCU.
    The two modules are connected through a cable.
    You probably need to replace the keypad (control panel).
    See my last comment with link to parts seller.
    Good luck.
    Ginko
  • 4,323 Answers
Hi
Reset the power to the dishwasher and unplug it for 10-15 minutes. Try and check after 15 minutes what LED's are blinking. Also make sure the door is latching properly and there is continuity present on door switch.
Hope this helps...please post back for further assistance.
Daniel
Posted on May 29, 2011
  • Daniel Scott
    Daniel Scott May 29, 2011
    Alright. Let me know how it goes. These issues can occur due to faulty door switch.
  • Daniel Scott
    Please check this video---
    Daniel
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
I have a Kenmore elite dishwasher. The Pots and Pans red light is flashing and the Heated Dry light is solid red. Nothing I do will change that. I've tried pushing any combination of buttons and ...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 19, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a whirlpool adp951 with a green light flashing
HI,
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Clean light flashing and unit wont run
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Jan 24, 2009 | Whirlpool Dishwashers
Dishwasher light flashes 7 times
although i dont have a lookup for your particular model number. if you remove the lower access panel you will find techsheet/troubleshooter. in it there will be section on "clen light blinking 7x" foplloe direction to put into test mode to clear the fault. belive its,,, heated dry/ sani rinse / heated dry/sani rinse. pushing htese buttons is what gets into test mode
Dec 11, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwarsher
This worked great - press Sani Dry, then press Heated Dry - then repeat - press Sani Dry, then press Heated Dry. All control lights will light and then press Cancel. The control panel should work normally.
Nov 05, 2008 | Kenmore 24 in. 17033 Built-in Dishwasher
Start light blinking
Test mode is Heated dry - Normal - Heated dry - Normal in 6 sec....
does it blink slowly or three time or fast or 7 times then repeat... let me know and I can help
Jul 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
433 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
