Question about iiyama Vision Master Pro 450 Monitor
For many years, my monitor will flash too bright ocassionally. And it will stay too bright until I jiggle the whole monitor. I thought it is the connection in the back of the monitor, and if I jiggle this connection, it does , indeed, affect this problem. But, I can't tighten this connection any more than it is. Plus, the problem always comes back. Once I get the bright flash gone....everything looks great for a real good while. I used to think it only happens when a page comes up on my screen that has a lot of whiteness to it, but really, if I'm on any page...it can start to flicker too bright. Sometimes, it corrects itself. I have tried using the Degauss button, but that doesn't permanently fix it.
  • 20 Answers
There is the problem with ur mother monitor mother board i.e. solders get moistures u have to re soldering the all the components of ur monitor mother board.
best solution is the, go to the nearest electronics repairing shop near by u.
Posted on May 29, 2011
Dim screen on a dv1000, flashes to full brightness on jiggling to lid switch
The CCFL lamp maybe faulty or the wires from the inverter to the CCFL lamp may be loose or need re-soldering.
Apr 06, 2013 | HP Pavilion Computers & Internet
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Samsung Syncmaster 204T flashing
Please check that all the cables are plugged in firmly on the back of the monitor and on the back of the computer.
However....
It sounds like the back light on the screen is faulty. If this is the case it is definitely a return for repair problem. You should be able to find the warrantly procedure for your area on the samsung website.
Cheers
Dave
Jun 21, 2009 | Samsung 204T 20" LCD Monitor
Brightness box
I suggest you to track faulty component at logic board.
Apr 19, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Ocassional flickering
Not sure what the problem is, but am experiencing the same symptoms every few minutes on a Mitsu Diamond Pro 91TXM, just retrieved from storage after 7 years. How's your screen holding up since April?
Apr 17, 2007 | Mitsubishi Diamond Pro 900U 19" CRT...
Monitor stays dim
Chances are it's not the actual CFL back-light bulbs themselves, but the back-light inverter board. If it was the bulbs you would have not had the "warm up and it get bright" issue. The board IS replaceable, (as well as the bulbs) ViewSonic charges about $36.00 USD for the board when they have them in stock. (out of stock as of yesterday 11/14/2006) It should be covered under warranty if you got longer than one year. (I know the warranty was only one year on MY VA800 but I have seen longer offered since i got mine) Good Luck I hope this helps! El Duderino
Nov 11, 2006 | ViewSonic VA721 17" LCD Monitor
iiyama Vision Master Pro 450 Monitor Logo
111 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
