Question about E-Machines (T2958) PC Desktop
Trouble with video graphics
I have problems with my graphics anytime time put the computer on. The graphics appear undesirably poor.Please I am seeking for graphic drivers please help me out. Thanks so much.
    Scholar:
  • 94 Answers
Do you mean that the icons look very large and colours are a bit harsh? if so it could be that the screen resolution is set to low.
Try this...
Right click on the desktop, and choose 'properties' from the list
a new dialog box will appear called 'display properties'
along the top is a series of tabs, the last one is called 'settings'
click on this and you will then see details of your screen resoulution.
Halfway is a slide bar called screen resoultion
for example..
less -------|------- more
move the slider untill the numbers change to 1024 by 768 pixels
to the right is another box called colour quality - change this to 'highest (32bit)
click apply
click ok
the screen will briefly go black then you will see the desktop, you will get a confirmation box asking along the lines of 'do you wish to keep these settings' click yes to this
have a play with the desktop, open some windows and see if they are now fully visable to you without having to scroll.
You can go back and change your resoultion anytime you want, by following the above. But take note, some monitors will not display all the resoultions in the list, you will get a message to say if it is or not. Just play with the settings untill your happy.
Hope this helps
Regards
Please remember to rate.
Posted on Aug 16, 2008
I have dv2840ee laptop. no display, power on. i remove coms battry, i put the lcd monitor. display came. but i go to bios appear only hdd test and rem test . system Bios shadowed & video bios shadowed...
This model has a common issue where the video chipset solder joints break and cause graphics issues.It requires fe flowing of the graphics chipset or a replacement motherboard.
Mar 12, 2012 | Computers & Internet
Hi,i actualy bought an aoc 2243fw2k led monitor,i hav a nvidia geforce 220gt graphic card,even though i installed the latest drivers for both graphic card n the monitor,i stil cant experience high...
1920x1080 resolution is the starting point for HD video. If you have set your desktop resolution to that or anything avove then you should be running at HD resolutions. Maybe the image/video you are watching is not at a HD resolution, therefore it will appear distorted and streched (poor quality). To fully experience HD playback use video files and imaged that are at the 1920x1080 resolution and above.
Dec 16, 2011 | Computers & Internet
Hi, my problem is: SOmetimes, my monitor have bad color, it doesent looks like usualy, it looks bad, the color is different, bad, it appears in a grey fundal, transparency, i donw know what is the problem,...
Check the video connection cable. Unplug it from monitor and computer, and fix it again, completely screwing it. When there is poor color, try to move/slowly pull the cable on both sides. The best solution to try is to install a completely new video cable.
Hope it helps. Dan
Sep 22, 2011 | HP Compaq 1720 17" LCD Monitor
My laptop lg x130 stuck for almost a month when i turn on it the screen has no display
The display of your laptop is one of its most integral components, and if it is exhibiting problems, it is one of the most frustrating issues you can experience as a computer owner. A display can experience a variety of issues, from the mildly annoying flickering of a screen, to it not powering on at all. Identifying the problem is the first step towards assessing whether it can be fixed, or if it is time to get a new computer.
  1. Brightness
    • If the brightness of your screen is intermittent, or is flickering, it is likely that the inverter is broken. The inverter is a small board that controls the brightness of your screen. It plugs into the display and the motherboard, or the main brain of your computer. Try a new inverter board, which you can get from your computer manufacturer, or from a computer supply store, by taking out the inverter from your display casing.
    Garbled Video
    • If there is garbled video on your screen, it may mean that the low-voltage differential signaling cable, also called an LVDS cable, has begun to malfunction, or that the graphics card is failing. To check your LVDS cable, open up the computer and unplug the LVDS, which will be running from the motherboard up into your display. Plug the LVDS cable back in and with the computer open, turn the computer on and check the graphics. If it continues, you may need to take the display out of its casing and unplug the LVDS from the back of the screen. If the graphics issue continues, try another graphics card. If the new graphics card is in, and there are still graphics issues, the LVDS will need to be replaced.
    No Video
    • If there is no video on the screen of your laptop, it can mean one of two problems: that the display has completely given out, or the logic board is not supplying any video to the screen. If there is no video, try moving the screen forward to back several times to see if video appears momentarily. If so, there may be a loose connection. If no video comes on, hook up an external monitor to the computer and see if any video appears. If video does appear, it is likely the screen has died. If there is no video, your graphics card has failed. Depending on the logic board holding the graphics card, you will either have to replace the graphics card, or the whole logic board.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | LG Computers & Internet
My computer turns off and on again for a few seconds. (this time it will bootup) when i pressed the power button. i already change the ram to 1gb but the problem still occurs. What can i do to fix this...
It may be owe to software problem 1, the virus "shock" virus attack will prompt system will automatically start in few seconds. From the remote control you Trojan program all the activities of the computer, including let your computer restarts. Remove viruses, trojans, or reshipment system. 2, the system files damage system files destroyed, as the KERNEL32. Win2K DLL Win98 features, the font list below such basic execution system files destroyed at startup, system will therefore cannot finish initializing and forced the restart. Solution: cover installation or reinstall it. Hardware problem: 1.Chassis power is not enough, dc output is pure, the dynamic response sluggish. Users often ignored or assembling businessman, using cheap price of power supply, so is the largest system of automatic restart suspicion. (1) the power output power shortage, when run large 3D gaming occupy CPU resource of software, the CPU needs power supply, power is not caused by overload protection, stop the power output. After the output power to stop, load, reduce power restart. Due to the protection of the recovery/time is short, so we are hosting automatic restart. (2) power dc output is pure, pure dc power supply of digital circuit requirements, when the power output of too direct, the harmonic content will result in digital circuits, performance is often work to crash or restart. (3) working load of the CPU is dynamic, on the current requirement is dynamic, and the dynamic response speed quickly. Request Some of the poor quality power dynamic response for a long time, could also lead to crash or frequent restart. (4) high-end graphics update equipment (large disk/video card/equipment (increased), after the hard disk) / burners, power supply of original beyond rated output power will cause the regular crash or restart. Solution: now in high quality high-power computer power. 2.The memory chip thermal stability, incorrect or damage to restart the system memory problems to restart the system of risk. (1) the poor thermal stability of memory, boot can work normally, when the memory to a certain temperature, temperature is can not work normally, which leads to crash or restart. (2) memory chips, slightly damaged, also can pass on self into the system, when the operation can be some big software throughput will restart or crash. Solution: replace memory. (3) memory of CAS value too small can also lead to instability caused by system memory, automatic restart. General had better use the default Settings, don't roll change yourself. 4.The CPU temperature exorbitant or the cache damage (1) the CPU temperature exorbitant often causes protective automatic restart. The basic reason of high temperature is due to poor cooling chassis, CPU, the CPU is undesirable reasons: the heat radiator thermal conductivity low, radiator material with a foreign body between CPU interface (1) for quality assurance, fan speed is low, the fan and radiator dust too much, etc. And P2, P3 motherboard CPU temperature probe damaged under the mp4 or within the CPU temperature detection circuit on the mainboard damage, the BIOS BUG in a special conditions of temperature, the CPU CMOS setup to protect low temperature, etc. Can also cause protective restart. (2) of an internal CPU, level 2 cache damage is CPU common fault. The extent of damage, or can start, when running into the system, the software (some throughput big media player, games, 3D graphic) will restart or crash. Solution: in the CMOS setup of shield (L2) or level 2 cache cache (L1), 1 or replace the CPU. 4.AGP display, PCI CARDS (nics), cat restart automatically (1) the external card or poor quality work not standard, AGP/PCI bus signal misoperation cause system RESET to restart. (2) and graphics, loose network system may cause restart. 5.Parallel, USB access is serial, fault or the incompatibility of external devices restart automatically (1) the fault or not compatible with the parallel damage, such as printer, a foot of short-circuit, USB equipment damage of short circuit, signal level sutural definition, opaque, etc. (2) hot swaps external devices, shaking, cause signals or power instant short-circuit. 6.Mainboard failure In case of automatic restart motherboard is rare. Generally RESET circuit are associated with a fault, Socket weld is empty, slots, contact undesirable, Individual chip, capacitance elements such as damage.
Jun 23, 2010 | Acer Aspire 4315 Notebook
Can i put a ati radeon 9550 graphics card in a dell dimension 2400
You can put any graphics card in any machine you just need to install the proper driver
Use to be a jumper on the mother that disabled the onboard video but today I think the soft hardware saves use the trouble.
You can run 2 monitors at one time using the 2 video graphics... card and the one on board just set you display properties
Jul 30, 2009 | ATI RADEON 9550 Graphic Card
I've added a new graphics card and now get no sound.
I SUGGEST YOU READ A MAGAZINE CALLED CPU [COMPUTER POWER USERS]
FROM 11/2008 TO PRESENT ISSUES
ROD
Mar 12, 2009 | Computers & Internet
Aiptek video
Shouldn't you have investigated the file transfer abilities of the equipment before you purchased the camcorder ?
I am not a Mac expert, but usually the software that comes with electronic devices is designed to be Windows compatible.
Mar 28, 2017 | Aiptek A-HD 720P Flash Media Camcorder
Trident graphics card
your graphics card need drivers as you computer is only running on basic video what is the card name and number please
Aug 01, 2008 | Trident BLADE T64, (32 MB) PCI Graphic...
Per pixel rendering problems
you should update your software about 25 pounds i wish to say mysterious
Nov 10, 2007 | Computers & Internet
E-Machines (T2958) PC Desktop Logo
49 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
