Question about John Deere Garden
The mower will start and run for a few seconds, then quit. The gas is new. What can I try?
  • John Deere Master
  • 7,482 Answers
Hi cbeaux2002
Try these solutions to your problem..
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 29, 2011
Engine won't stay running - only will start with starting fluid.
VERY COMMON problem with gas engines.
I recommend starting all your gasoline using machine ever month or two. Let them run a few minutes. Same with cars/trucks.
Start you r car/truck every couple months and drive forward and backward several feet as well.
If you have a gas shutoff valve, turn it off and run engine till all gas is out of carb before storing.
Gas turns to a hard lacquer is sitting too long. remove air cleaner covers, Pour some real good (strong/thorough) carb cleaner in carb and leave sit over nite. If that doesn't work, do it another nite. If not working yet, you may have to take carb off and open it up. Be careful there are little tiny parts in there.
Apr 03, 2016 | Garden
Mower starts easily, but runs 10 seconds and quits.
Carburetor needs to be cleaned; main jet is clogged with debris, dirt, whatever.
Jun 23, 2015 | Garden
Won't start.
Depending on the age of the mower, the problem is probably the carburetor. The holes for fuel flow in the carburetor are so small, they can rarely be cleaned. I would suspect you will have to replace the carburetor to get the unit to run properly.
May 06, 2015 | Garden
Weed eater starts but only runs for a few seconds and cuts off. prime it and starts but only runs for a few secounds and cuts off again
check gas line in gas tank. See if Stone filter broke off of gas line.
Very common with this new crappy Ethanol gas
Aug 23, 2013 | Garden
My lawn mower will start then it will die after a few seconds, what could be the problem
If the mower was tipped it is quite possible oil from the engine has traveled up the breather and soaked the air filter in oil, this would richen the engine up and stop it running, remove the air filter and check for oil saturation.
Jul 18, 2012 | Garden
Lawn mower does not run.
Needs a new diaphragm. Its between the carb. and gas tank. It collapsed and doesn't allow enough gas to carb. to keep motor running.
Apr 10, 2010 | Mtd 22" Yard Machine Push Mower
Won't start after killing the motor
May need more info. Check for a seat switch to have came unpluged (wiring) this is a safty thing. You have to have your foot on the brake as you sit in the seat to get it to crank. repost if you need more help.
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine won't start . Pour gas in cylinder it starts then quits.
hi lou. your carbeurator is gummed up. It will need to be removed, soaked in carb cleaner for three hours and then rebuilt using the correct kit.
if you are not familiar with how to do this i recommend that u have it done by a lawn mower pro
May 28, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
657 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
