Question about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
Changing belt on husqvarna cth 171 - Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
2 Suggested Answers
  • 3 Answers
SOURCE: I have a Husqvarna CTH 171. When i engage the blades they
Does the lever that engages the blades have pressure on or does it feel loose. It is possible that the linkage from the lever to the idler pulley has come off. Raise the hood and watch the lever as it is engaged and disengaged there shold be somekind of linkage moving a pulley in and out to tighten the belt so the blades will turn. hpope this helps
Posted on Mar 03, 2010
My model Husqvarna CTH 171 does a great job as a tractor, hauling stone, wood etc. Recently it does less well at grass cutting. It cuts at the highest setting, but as soon as I lower the deck the engine...
It sounds like when the unit is under more load it stalls out. It could be that bearings on mower need to be greased or replaced. Or it could be something internal. I would personally check compression with a compression tester. They are fairly cheap and easy to use. They simply thread in spark plug hole, you turn unit over and observe gauge. Probably a good tune up with valve setting checked/adjusted would be a good idea too.
Oct 18, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Hi Team. I too need a diagram to install the belt on my 2007 Husqvarna CTH2036 cutting tray. Can you help please. serial. 082207C001009. product. 960610217 01
The CTH machinesw have counter rotating blades, there should be a scimatic of the belt routing on the underside of one of the foot wells
Dec 03, 2012 | Husqvarna Garden
Husqvarna cth 180 the shaft as brocken on the rear axle can I replace it
to replace it you need to remove the rear assembly then open the rear axle assembly
Jun 16, 2012 | Husqvarna Garden
Hydrostatic on husqvarna cth 180 xp losing power
Check the drive belt. This belt runs from the engine to the transaxle. Look for abnormal wear and if the sides of the belt look glazed/shiny. Check the pulley mechanism that tightens the belt for proper operation and belt tension while engaged.
Try reducing the speed selector. This is equivalent to running in a lower gear. Your tractor works hard just to turn the blade. Going uphill requires additional power, so some reduction in speed is to be expected.
May 06, 2012 | Husqvarna Garden
CTH 171 Mower starts and runs fine but lacks power to climb even gentle slopes whether or not it is cutting.
The mover has great vibration as all mowers do. That is why the valves are recommended to be regapped at every 250 hours of running time. If not checked the engine will run although will be reduced in power going up a grade. Eventually it will not start so easily if not serviced soon
Jul 09, 2011 | Husqvarna Garden
http://weborder.husqvarna.com/order_static/doc/HO/HO2005/HO2005_5321938-34.pdf
This is the owners manual if you do not have one.
There is a brake on the pulley, make sure that is not hanging up.
Please let me know what you find.
Feb 08, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Need a new drive belt for a Husqvarna cth 130 hydrostatic ride on mower how much are they
Depending on where you live they cost between $30.00 and $50.00 dollars some are as high as $75.00 becuase of the type of belt that it is.
Aug 19, 2009 | Husqvarna Garden
We have a husqvarna cth 170 and we cant seem to reverse it... have any ideas on how?
I have a Husqvarna YTH2348 that clicks when i try to start... I had the battery tested and changed the solenoid and still won't start. How do I check the starter????
Jun 05, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c33%5c28%5c0009.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Jan 23, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
292 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
