Question about Sigma Sport BC1106 Dts Wireless Bike Computer
How do i get the odometer off to change battery'
    Brigadier General:
  • 8,546 Answers
Can't reset oil gauge on 2006 Lexus 430
Instructions
    • 1 Turn the ignition switch to "ON" without starting the engine.
    • 2 Press the trip odometer button to change the display to the total mileage.
    • 3 Turn the ignition switch to "OFF."
    • 4 Press and hold the trip odometer button. Turn the ignition switch to "ON."
    • 5 Release the trip odometer button when the oil change maintenance light resets.
Oct 17, 2012 | Lexus GS 430 Cars & Trucks
I have a 2003 ford escape & the digital odometer doesn't work correctly
Have the dealer do a speedometer accuracy test. They have a special tool that can electronically read the speed and then compare it to the readout of the odometer.
Jul 16, 2012 | 2003 Ford Escape
How can i make the little red engine lite go out on my 2000 nitetrain?\r\nIt only comes on some times after a long hard ride i.e.100mi@90f temp. Oil tank is full only 2600mi since change. Thanks, G.S.
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
Jul 19, 2011 | 2000 Harley Davidson FXSTB Night Train
Replaced battery on 98 Porsche Boxster and now odometer is wrong
I had the same problem and was about to take the car to the dealership tomorrow, but I decided to try disconnecting the battery and see if it would reset itself. When I reconnected the battery the odometer mileage went back to where it was before I changed the battery. It worked!
Maybe it will work for you. Good luck!
Mar 17, 2009 | 1998 Porsche Boxster
The odometer reading disappeared on my '98 Volvo S70.
Have you found anything out. I brought my volvo in to have the battery replaced and when I picked it up I noticed the odometer was blank (no -----) just blank. I was told it was not related and probably just a bulb. Not a bulb I have no idea. I don't want to replace the cluster unless I'm sure what have you found out. (all my other gauges are fine speed, tach, trip fine)
Jan 20, 2009 | 1998 Volvo S70
Sigma Sport BC1106 Dts Wireless Bike Computer Logo
131 people viewed this question
Top Sigma Sport Cycling Experts
kirkjw
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Sigma Sport Cycling Expert? Answer questions, earn points and help others
