Question about Kenwood Audio Players & Recorders
Bought kenwood a-45 amp and age-450 graphic equaliser connected as should be but am getting no sound any ideas
Wiring diagram for a-45 stack system
Posted on Jul 23, 2011
Idealistic graphic equaliser model 31-9081
Connect your Denon outputs to the Realistic main inputs.
Connect your Realistic main out to the Rotel tuner in.
Connect your Technics out puts to the Realistic Tape 1 inputs.
Connect your tape 1 out puts to your Rotel cd inputs.
And you should be good to go.
May 02, 2016 | Audio Players & Recorders
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
Connect a denon amplifier pm-510ae to a technics equaliser sh-8058
Hi Just to let you know what ever you put between the amp and speaker you will degrade the sound quality. Even with the best machines you will muddy the sound. If you read HiFI magizine they will tell you this is true.
But if you don't care about the quality of sound than go ahead hook an equalizer on it. Hope that helps you.
Mar 27, 2012 | Denon Audio Players & Recorders
How to wire up kenwood ge-760 graphic to my
First of all connect the source, the tape or the DVD, to the input of the equaliser, use the output to connect to the AUX of the amplifier. make sure that the L&R are not crossed over. In case your amp has an in and out of the preamp section use then connect the source to the amplifiers input specified for the source like tape or DVD or TV and use the preamp output to the equaliser input and the output of the equaliser to the input of the main ampflier. Now the bass and treble of your amp can be set to the mid point - 12 noon position and use the boost or attenuation according to your choice of music. hope you find my advice helpful. Good day
Jul 04, 2010 | Kenwood Audio Players & Recorders
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
Kenwood Components
MAKE SURE U HAVE ALL OF THE COLORS MATCHED UP ON THE WIRES
Sep 09, 2008 | Kenwood KDC-MP4028 CD Player
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Aug 30, 2008 | Audio Players & Recorders
Yamaha Natural Sound Amp and Tape Player
All of this applies to nearly any analog consumer audio gear...
If you have any Tape Deck and an Equalizer and only the one Tape Monitor loop you should place the EQ into that Tape Monitor loop, then place the Tape Deck onto one of the probable two Tape Monitors on the EQ as it sounds like you had here...
"When I had it set up with the graphic equaliser,pressing tape monitor on the amp and on the equaliser gave me play backfrom the tape player."
That setup will allow you to apply EQ to any analog source and the tape deck in record or playback mode.
However, if you want to remove the EQ and use the Tape Deck directly on the Tape Monitor just attach the deck's Playback cables to Tape Mon In (Play) and the deck's Record cables to the Tape Mon Out (Rec). Flip the Tape Mon control to hear the tape deck or monitor it while recording.
NEVER plug anything but a turntable into the Phono. It has a preamp that expects a ver ysmall signal from the cartridge AND it also has a severe RIAA Equalization curve which would result in grossly exaggerated frequency extremes if you managedto get a non-LP source into it. Likewise, turntables without internal electronics mut always use the Phono section of a receiver, preamp or integrated amp to get the boost and EQ they need.
Mar 23, 2008 | Yamaha RX-Z1 Receiver
KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
BIG RED
Oct 30, 2007 | Yamaha DSP-A3090 7-Channel Amplifier
428 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
