Question about Crock Pots & Slow Cookers
Cant get my pressure cooker to 11#
My pressure cooker will only raise to 1# even increasing the heat will not raise the pressure to 11#. What can I do?
    Novelist:
  • 72 Answers
If your pressure cooker is a 110VAC electrical unit, and it has a Robertshaw Manual Temp Controller on it - then chances are it is bad if you are having any problems with maintaining a controlled heat to the melting pot.
If it's gas fired then you have a venting seal problem somewhere. Check to make sure everything is in it's proper place and alignment.
Anything else just ask me and I should be able to answer your ??'s as I've worked on similar equipment for the VA Hospital.
Frank
Posted on Aug 21, 2008
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
Looking for manual for the Farberware 7 in one programmable pressure cooker
pressure cooker manual & recipe booklet library ' hip ...
www.hippressurecooking.com/pressure-cooker-manual-library/
Free downloadable copies of pressure cooker instruction manuals for stove top pressure cookers, ... Farberware Quick Cuisine Pressure Cooker Recipe Booklet.
FARBERWARE FCP412 USE & CARE INSTRUCTIONS ...
www.manualslib.com > Brands > Farberware Manuals > Coffee Maker
View and Download Farberware FCP412 use & care instructions manual online. ...Salton use & care instruction programmable coffeemaker fcm12ss (12 pages) ... TOLL FREE: 1-888-881-8101, Monday - Friday, 7:30 a.m. - 6 p.m. CST Please ...
Farberware 6-Qt Digital Pressure Cooker - Walmart.com
Jan 01, 2016 | Crock Pots & Slow Cookers
I have a wolfgang puck pressure cooker that keeps shorting out and tripping the gfci within 1-4 minutes. What can I do?
You may have a faulty GFCI...test it and again with a known good appliance.
If the GFCI holds, then you have a ground fault in the pressure cooker. Either disassemble the cooker to the electrics and fix the short or return the cooker under warranty.
Chances are you can even get a replacement outside of warranty if you talk nice to the company.
Google it and get the company website.
If you bought it from bed bath and beyond just return it, hopefully with the receipt.
Feb 25, 2015 | Wolfgang Puck Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Se e4 on my cooker what do i do
    The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
    Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
    I do NOT know how to use i.e keep at pressure without burning stuff. This is my daughter's Sambonet pressure cooker, it has a strange looking style of lid lock down that is part of the pressurisation...
    Pressure cookers rely on pressure and steam,
    Do a dry run first...well not dry but with just water, (no food) especially if it's an old cooker.
    Inspect for cracks or pinholes before you go ahead, a crack ANYWHERE in a pressure cooker makes it a bomb...or a flower pot.
    Ensure all safety devices like the pressure regulator and blow out plug are in good condition and not plugged.
    If some previous owner replaced the blow out plug with a bolt or something silly don't use the cooker till it's repaired.
    Bring your pressure cooker slowly up to pressure over medium heat with an inch or two of water in the bottom.
    When it starts to vent steam turn the heat down so the steam barely escapes, if it has a rocker weight it will wobble a couple times a minute.
    Slow gentle heat is the trick. A cooker will run for hours like that without boiling dry.
    A couple tips, use salt and spice sparingly, it's trapped in there and permeates the food.
    Be careful with foods that expand on cooking like rice and dried things, they can get up and block the vents if they reach the lid.
    TickMagnet
    Jul 22, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
    How do i increase the water pressure in t boiler
    you can not increase the water pressure with the water heater if your on city water you are stuck with the pressure you have if you have a well you can increase the pressure switch.
    Nov 11, 2009 | Crock Pots & Slow Cookers
    Cooking PLAIN rice
    Here is my recipe - enjoy and please rate my answer as a fixya!
    Raw Rice - 2 Cups (400 gms.)
    Water - 6 Cups.
    (The ratio of rice to water is 1:3)
    PROCEDURE
    Step 1:First wash the rice in water thoroughly and drain the water.
    Step 2:Take a vessel ,the capacity of which is double the quantity of raw rice that is to be taken.
    Step 3:Now,add the washed rice into this vessel and pour 6 cups of water into it .
    Step 4:Now, place this vessel containing rice with water in a pressure cooker and add the pressure weight on the cooker top.
    Step 5:Heat the pressure cooker for 20 minutes only.
    Rice has been cooked.
    NOTE:
    *After heating the cooker for 20 minutes,donot open the cooker immediately.Wait for 15 minutes and then open ,otherwise the cooker would burst open.
    Feb 16, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
    Ultrex pressure cooker model innova 14240
    Pressure cookers are only slightly more complicated than crock pots. In fact, you can think of them as the opposite of Crock pots. Where a crock pot needs 2-3 times as long to cook something, the pressure cooker needs only 1/2 to 1/3 of the time.
    These are not that complicated and haven't changed in the last 50 years. The only real hard part is being sure is doesn't explode; not that hard: don't cook things that would foam, like pasta or potatoes. Just read some recipes on the internet or get a recipe book at a bookstore, used book store (super-cheap)or the library. My best advice is to make sure you use the lowest possible heat that still allows steam to escape at a whisper. That will keep things from burning (or scorching) on the bottom, which can give a harsh taste and make clean-up more work. Just do it.
    Jul 20, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Crock Pots & Slow Cookers Logo
    69 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    tsalagi152
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
