Question about Belling XOU487 Electric Double Oven
How is the b170f belling main oven door removed for replacement of hinges?
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Posted on Nov 20, 2008
  • 5 Answers
SOURCE: my belling oven door
get these instructions and look at door removal
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
if the glass has come away from the metal inside doror its was originally secured by a silicone sealant/adhesive. Try Toolstation 59104
Posted on Mar 29, 2010
  • 193 Answers
SOURCE: Belling Electric Cooker - Main oven keeps tripping electrics
yes use an ohm meter to test it
Posted on Apr 29, 2010
I wish to remove oven door from oven on a Belling BI60MFB to re glue fascia glass .Can't see clearly how to detach.
Having searched it looks like a pull down oven door. It is normally a case of locking the hinge. How to fix your oven door glass Oven Door Glue has a video which shows several common types of hinge, and how to remove the door.
Nov 07, 2016 | Belling Ovens
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
I have a new belling b170f and have just turned it on however the fan at the back wont turn off. how long would I expect the fan to run. The oven has not even been hot yet
If its less than a year old then call belling as it sounds like the thermostat for the cooling fan is faulty. Its designed to cut the cooling fan in at around 65 degrees celsius to protect electronics.
Mar 02, 2011 | Ovens
Belling 351 MK2AN Oven Door bracket back plate fallen inside!!
The only to do it, is to remove the side panel , and depending on the model number, you may have to remove the top also to gain access to the fixing screws.
Please rate my solution.
Thanks.
Nov 07, 2009 | Belling Ovens
The main oven door will not shut tightly, how do you adjust it?
if its a pull down door the hinges are prob worn and need replacing.
Sep 27, 2009 | Belling XOU492 Electric Double Oven
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
My belling oven door
Jan 29, 2009 | Belling XOU487 Electric Double Oven
Belling oven door not closing fully
Oct 17, 2008 | Belling XOU252 Electric Single Oven
Main oven door will not close properly. Is there any adjustment for it.
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
May 06, 2008 | Neff U1421 Double circotherm Electric Oven
Belling XOU487 Electric Double Oven Logo
53 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
