Question about Toys
Peco Scissors crossover wiring diagram is getting at me!
    Problem Solver:
  • 11 Answers
What do you need to know?
The powertower peco last i knew didn't have any electrical wiring
Posted on Jul 05, 2015
How to replace battery on black & decker SZ360 cordless scissor
I found a 1200mah 3.6v NiCd pack at BatterySpace.com for $10.99 each, the lowest shipping cost was FedEx Ground at $13.04 so I bought three of them, I'm sure I know some others that will need the other two. The quote 5 days to ship, in case they need to assemble them from individual cells.
The only issue is that I probably will have to modify the tabs to match the wiring in the scissors body, I'm sure Mr Dremel will come through for me on this point.
Black and Decker is most certainly *not* the best place to look, they have an exploded-view diagram of the scissors but have discontinued all parts for this model.
Van
Aug 17, 2013 | Black & Decker SZ360 Cordless Power...
Need wire diagram for clarion 100eqb-4
Hi.You can get the wiring diagram of Clarion 100 EQB4 in the manual available here http://www.clarion.com/sg/en/MungoBlobs/807/898/VXZ756-AS.pdf
Jan 18, 2012 | Clarion Car Audio & Video
I need a wiring diagram for 1987 Chevrolet 3/4 ton
The Haynes repair manuals usuall have wiring diagrams in the back of book.Around $20.
Oct 16, 2009 | 1990 Chevrolet Crew Cab
What is the wire diagram for the 3way bx35 boss crossover
Hello rew_smith,
The wiring diagram is silk screened right on the top of the unit. If your diagram is missing or obscured, you can get one directly from www.bossaudio.com.
The first 3 pairs of connections for subwoofer, front, and rear inputs coming from your receiver or head unit. Top is left channel, bottom is right channel. The 2nd set of connections are the outputs and matched in function to the first set. These are connected to your amp(s).
To the right of the input/output connectors are the 12V +, remote and ground screw terminals. The 2 switches and 9 controls allow you to set the high-pass frequency and output levels for the front and rear channels, and the crossover frequency, bass boost, phase, and output level for the subwoofer.
Hope this helps.
Aug 23, 2009 | Boss Car Audio & Video
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
Wiring diagrams for installing tweeters and crossovers in a door
try 12voltresource.com or google "wiring diagrams for car audio"
Feb 17, 2009 | Car Audio & Video
How to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Oct 05, 2007 | CTG 2 ft. Stranded Wire Crossover Cable...
Wiring Diagram
Did you get this figured out?
Apr 28, 2007 | Hitron SEQ-554 7-Band Car Equalizer
Toys Logo
145 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
