Question about Cycling
Need left and right handle snap on covers. Where can I purchase these?
    Brigadier General:
  • 3,301 Answers
Most bike shops carry those
Posted on May 29, 2011
How CAn I open the freezer door On a RF263beaesr to gain access to the latch assembly that connects to the handle the part number that snapped is da67o3435 cap handle
repairs should be performed by a qualified service technician. you may not need to disassemble the door. hold the handle and shift the handle left or right to remove the handle. do the same to reinstall the handle.
Apr 18, 2017 | Freezers
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
Hi i would like to know how to add water for the honda goldwing 1500 gl i want to know what to remove to find the place were to add water
Sit on the bike and turn the handle bars to the right. Look on the left hand side where the left handle bar was and you will see a rubber cap. Remove the left plastic cover panel around it and remove the rubber cap. It has hash marks to measure by. Ad 50/50 antifreeze till you see it half way up the hash marks. Be sure the rubber cap snaps back on tightly all the way around.If you ever need access to the radiator cap it is on the right side under that plactic cover. But you can add coolant on the left side. This is the upper level resivoir.
Sep 03, 2010 | 1990 Honda GL 1500 Gold Wing
HOW DO YOU REPLACE THE DRUM IN A CANON IMAGERUNNER IR1600 COPIER
do you mean complete drum unit?
If yes, you need to open front cover, realese the blue handle, remove the left sideway cover ( cover above the bypass tray, that have handle in the middle and goes out in left direction - TRANSFER COVER ), you will see two handles, left and right of the drum ( green roller ), grab them and pull the drum unit out.
Reinsert new drum unit, put back the transfer cover, lock the blue handle and close front cover.
Hope that helps!
Aug 23, 2010 | Canon ImageRunner 1600 Copier
I have a 2005 acura tl and i just purchased the door handle covers for both the driver and passenger side doors. I was told at the acura dealer that the only way to replace them was to remove the door...
I had this too, on the left rear door handle cover. If you were careful, had a small and thin screwdriver (e.g. the kind you'd use on eyeglass hinges), you could bend back the tabs that hold the cover on and snap it into place. My mechanic told me the same thing, but told me if I were patient, the cover might snap on...saving me about 2 hours' labor cost. It worked!
Sep 14, 2009 | 2005 Acura TL
Plastic Handle on glass oval lid broke completely off. need a replacement
MOST COMMON PROBLEM WITH THIS RIVAL you cannot buy the handle but what you can do is go to a hardware store and buy a big wooden knob for 1.00 it even comes with its own screw ... you might have to snap off what is left of the old handle screw buy useing a screwdriver and a pliers and a quick twist and it will snap right off , then install your wodden one . its that easy ... one more note , the side handles on this pot snap off too without warning . so dont move it when its full , people have been burned BAD ... dont forget to rate this answer thanks and good luck
Feb 18, 2009 | Rival 38601 Smart Pot 6-Quart
Hitachi Lamp Light Came on
Good Day, CCooke;
Lamp Number for the 55V825 Model is; UX21516.
To replace LAMP remove Front Panel outwards until the quick snap disengages. There is small cover on the left hand side, using a philips screw driver; remove. Two more screws secure lamp, use handle to remove. ALWAYS, unplug TV from A/C power source first. Good Luck, big IRISH.
Sep 03, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Euro-Pro EP91 Quad-Blade 6 Won't Start
My wife was given this unit from an elderly gentleman that was done trying to make it work.
I just fixed the same problem as above. Note - I do not have a manual for this unit.
True above about the bowl cover being locked in position but found the key to make it work is also the white lid to the left of the bowl cover. I was locking and unlocking this white lid with no results. Then I removed the bowl cover and found the white lid cover was loose and easily removed this white lid to inspect inside ( why this cover removes I have no clue).
Anyway I was able to snap the white cover firmly on and turn counter clockwise to lock in place ( six o’clock position), then after putting the bowl cover back on and snapping in place it works.
Note - I do not need to turn the white lid cover to install or remove the clear bowl cover, this could be because it looks like one of the clear tabs might be broken on the locking area of the clear bowl cover. If you have two tabs the same shape on the bowl cover you may need twist the white lid clockwise to install and remove the bowl cover and counter clockwise to lock in place so the unit works, but now that my white lid is snapped firmly in place it hardly moves with the force of both hands trying to turn it.
Hope this helps someone.
Good Luck !
Dan L. P.
Jan 05, 2008 | Euro-Pro EP91 Quad-Blade Food Processor
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Cycling Logo
15 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
