Question about Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter
Scooter turns on (shoprider deluxe 888sl) but will not move all lights horn and indicators work but we just get a beep every 5 seconds whilst scooter is switched on. have checked circuit breaker and fuse and both ok.
  • 103 Answers
SOURCE: HAVE PUT SCOOTER TOGETHER AND CHARGED BUT IT
Make sure the scooter is not in freewheel.
Posted on Jul 23, 2009
skaterkid307
  • 86 Answers
SOURCE: scooter stops then jumps forward
mait be problem with moter
Posted on Feb 20, 2010
  • 61 Answers
SOURCE: Shoprider- wheelchair will not move-Lights keep flashing
This usually occurs when either the battery charger is still plugged in when the button is pressed to turn on the wheelchair, or if the joystick has got 'Locked'. On the majority of electric wheelchairs you can lock the joystick control so that the wheelchair cannot be moved, for instance, it it was left outside a shop. You would need a manual for the controller from the manufacturer to tell you how to unlock it. You should be able to find this online somewhere. Most controllers on shopriders are made by Penny & Giles (P&G Drives Technology). Hope thats helpful to you...
Posted on Mar 19, 2010
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 346 Answers
SOURCE: shoprider delux scooter
check key tubler is not faulty,no connection has been or worked loose,fuses for each battery are not blown press curcuit breaker to reset.get the wiring feed checked from batteries to see you have power by an electrician.
Posted on May 12, 2010
I have a shoprider echo when I turn it on the power meter works. The horn works. But there is a beep every 3 seconds. Please help
Your Throttle maybe out of neutral when you start the scooter.
Make sure your parking brake lever is on so the scooter is hard to move. If it is easy then it is not on and won't drive. Make sure there are not any cables that are disconnected to the motor and brake. Scooter Doctor App
Apr 28, 2016 | Shoprider Health & Beauty
Why don't the turn signals flash on shoprider cadiz deluxe?
hi Vic, there a little black board under the tiller part , it got a ribbon cable to it so take care if looking at it , there's a fault with the circult..
Regard
Rob
Help me Help you ...
Sep 24, 2015 | Shoprider Health & Beauty
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Scooter turns on but won t move
Hi,is this a description of you request:UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE?
Apr 02, 2014 | Shoprider Health & Beauty
My shoprider deluxe is fully charged ignition on and wont go
Does the scooter making a bleeping noise when you turn it on? Do all the lights / indicators work (if you have them fitted)
Sep 21, 2013 | Health & Beauty
It want run the lights come on the horn blows
Download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.I hope this has helped.Colin.
Dec 05, 2011 | Shoprider Sprinter Deluxe Four Wheel...
My shoprider scootie does not show whats left on the battery and the horn does not work. Any suggestions what the problem may be? Thank you
hi, ok, but does the scooter work besides the horn and battery indicator not working ?
If the scooter works okay then the problem is within the tiller control panel , that is the panel on the handlebars, Now it could be a loose wire so carefully take it apart and check to see whether there are any loose wires.
Regards
GeWiz
Jan 12, 2010 | Shoprider Scootie 4 Wheel Compact Travel...
My shoprider dasher just beeps
we just bought a shoprider monaco,after i cleaned it it did same thing just kept beeping,i found moving the free wheeling lever under back bumper a few times cleared it.Lever makes contact with a micro switch,on motor.
Hope this helps
Sep 09, 2009 | Shoprider Dasher 9 3 Wheel Scooter...
Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter Logo
134 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
