Question about Microsoft Windows XP Home Edition
My computer says i have no audio device cant ajust volume
Windows xp home edition e machie T2200
  • r3ynita Dec 31, 2008
    ok well i computer was going all wrong so i had to put in this recovery cd that emachine sent me. i did wat i told me and it erased all the programs i downloaded but it also erased the thing that adjusts the volume .... so i cant hear anything. WHAT DO I DO??
  • 22 Answers
YOU NEED TO FIND OUT WHAT TYPE OF AUDIO CARD IS INSTALLED IN THE PC.EMACHINES WEBSITE MAY HAVE A AUDIO DRIVER DOWNLOAD AVAILABLE.YOU WILL NEED TO GO TO THE WEBSITE,ENTER YOUR MODEL# AT SUPPORT AND DRIVERS PAGE AND LOOK FOR A AUDIO DRIVER DOWNLOAD FOR YOUR MODEL #
Posted on Aug 17, 2008
On my windows xp computer i have built in speakers and i used to be able to lisen to u tube now it has no sound tried ajusting volume and all the usual things but still does not have sound says your player...
Check the connection between your speaker and your computer. You can also try using a headphone if it produces sound. If none seems to work, then scan your computer with RadarSync to check if the drivers are updated. If the sound driver is outdated, then you would need to update them. You can use RadarSYnc to update by it's not free but affordable and worth your money.
David
Mar 18, 2013 | Microsoft Windows XP Home Edition
I can't install audio device successfully
Desktop or Laptop computer ? XP If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers if you don't have a motherboard disk you will have to download the drivers http://download.cnet.com/2000-20_4.html Tick in either the all software or windows software box On the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity. Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
Jan 30, 2013 | Microsoft Windows XP Home Edition
My pc volume has disapear
Jan 17, 2013 | Microsoft Windows XP Home Edition
Volume icon
If the volume control is all grayed out, locked like you said then your sound driver is missing or corrupt. You will need to re-install the sound driver.
Mar 01, 2012 | Microsoft Windows XP Home Edition English...
My computer will no longer play music or any kind of noise
Check that your speakers are plugged into the right jack either in your sound card or the sound panel on the motherboard. If no sound then try plugging speakers into another computer and see if they are working and have power. Go to "control panel" and click on "Sound and Audio Devices" and under the volume tab under Device Volume make sure that the "Mute" box isn't checked. Also check the "place Volume icon in the taskbar" box if it isn't already checked. Go to the Volume control on the task bar and check out the audio volume levels and make sure they're not turned all the way off. Also under "Sound and Audio Devices" underl Volume tab click on "Advanced" and make sure that you have selected the proper kind of speakers in the speaker setup box.
YOu didn't say so, so I'm assuming that you're using Windows XP. If you're not the menus may be a little different but similar.
Sep 29, 2009 | Microsoft Windows XP Home Edition
My computer can't play no sound I went to sound
When did sound work fine on your computer. Try this :-
Open device manager(Start - run - type devmgmt.msc) and expand sound video and game controllers.
Right click all the submenu underneath and choose uninstall.
(Note : All the menus will not give you an option to uninstall, dont worry)
Uninstall those which gives an option followed by restart your PC and see if it works.
If it doesnt, click start - run - type services.msc and look for windows audio service - make sure ot is automatic and started, if not make it.
Let me know the status.Awaiting response.
Thanks.
Sep 08, 2009 | Microsoft Windows XP Home Edition
Volume control program installation
go to the control panel, open the sound and audio.
check the box in front of "place volume icon in the taskbar", under the device volume, in the volume tab page.
Mar 17, 2009 | Microsoft Windows XP Home Edition
Deleted audio output device on Microsoft Office Home Edition
Hi!
Take mother board cd and install audio drivers....That's it..
bye & take care....:)
Mar 13, 2009 | Microsoft Windows XP Home Edition
No sound device
u have reinstall sound driver
Oct 07, 2008 | Microsoft Windows XP Home Edition
Acer aspire 4720z audio driver for widows xp home edition sp2
welcome to fixya
the only thing i could tell you is to try to reupdate the divers through the device manger if this does not work then you might of blown the soundcard in the machine
hope this helps you out sorry not better news
have a goodday :)
Jul 26, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
