Question about HP Compaq ProLiant DL380 G4 Server
My HP DL480 G4 will not power up. The internal LED cycles between 00, 40, 80 and C0. When I press the power button the fans start, but then stop.
  • Ray Hinchliffe
    Ray Hinchliffe Jun 04, 2011
    Resolved. A VRM had failed.
engrkoiled
  • 34 Answers
SOURCE: flashing led power button on deskjet d2460
try to check your cartridges. Pull it out one at a time then try to see it it stop blinking. Especially cartridges that was refilled. Improper refilling of cartridges causes them to stop responding to your printer and causes to malfunction. this was base from my experience.
Posted on Mar 26, 2009
jmgldsmth
  • 1869 Answers
SOURCE: no power when i press button...led fashes 8 times
remove and, reseat your memory if that doesn't help try disconecting your dvd drive hard drive(s) one at a time and, retest
Posted on May 24, 2009
leecom72
  • 4806 Answers
SOURCE: HP Compaq nc6000 wont start up
Hi there.
This could be a problem with the system memory.
Take the battery out and the AC power, turn the laptop over and look for a panel with screws on it, unscrew the panel and you should see something like this >>>>>>>>>
Unclip the memory by pushing the little lugs outwards and the memory should pop up ready to be taken out, get a clean dry paintbrush and clean the memory and the slots.
If you have more than one stick of memory just put one of them back and try booting the laptop up.
If one works try the other and see how you get on.
Post back for any additional help
Good luck and thanks for using FixYa!!
Posted on May 26, 2009
geo_jonas
  • 555 Answers
SOURCE: Server crashed
need to have re installation of your Operating System
Posted on Jun 16, 2009
antiochpc
  • 1314 Answers
SOURCE: DC5100 want start up
You need to replace the power supply, a fairly common problem.
Posted on Jul 17, 2009
My Panasonic split air conditioner has stopped cooling - model:CU-W18DKR. The internal unit and internal fan operate normally. The external unit fan does not run like normal and no compressor sounds f
Sounds like a faulty outdoor controller board. If you are in Australia, call Prime Electronics or Statewide Appliances for spares.
Part number: NPCWA743383
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
Or better yet, get a tech to check first.
Feb 10, 2015 | Panasonic Single Split System - Wall...
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Hp Proliant ML350 g4 will not power on. System was on but not responding so used power button to shut down. Now no response to pressing power button. No LEDs lit anywhere. Fans running on power supplies.
sounds like the motherboard has gone.... you could try changing the PSU and popping out some of the ram boards to see if that helps. but with the symptoms you've said, i'd say its the motherboard.
Oct 28, 2013 | HP ProLiant ML350 G4 Server
ML350 G3 S/board CPU Error Amber LeD + Internal Health Error
You will continue to get internal error until you add memory. It shouldn't even boot without RAM.
Feb 04, 2013 | HP ProLiant ML370 G4 Server
Proliant ML350 g4 internal health led: red and green alternate
Open the case and turn it on. There should be corresponding red light indicator inside or possibly the back.
Dec 03, 2012 | HP ProLiant ML350 G4 Server
I have the same problem with 3 motherboards ML350 G4: I connect de powersupply to the backplane, all the fans starts, the row of leds on the mobo begins the check secuence with green status but ends with...
Have you already connected both power jacks to your board? It's motherboard needs two supply of power. One is near the cpu fan and the other is at the right side end. Check also if the power supply has the same value as your power outlet. Low voltage can still cause this king of problem. 220 Volts - 220 Volts, 110 Volts - 110 Volts. Hope this could help a little friend. Have a nice day.
Aug 20, 2011 | Compaq 365062-001 - System Board ML350 G4...
My "hp pavilion a220n" won't
Check all wires for loose connections--- if the memory was wrong or something, it would still attempt to boot but stop during the POST and start to beep
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
If I open and close the printer it starts as if it is doing printer prepeartation, but nothing comes on. The screen will not turn on.
  • SOLUTION 1 If the HP All-in-One is turned off, press the On button to turn the unit on.
  • Unplug the power cord from the back of the HP All-in-One.
  • Wait 15 seconds.
  • Plug the power cord back into the HP All-in-One.
  • Turn on the HP All-in-One by pressing the On button.SOLUTION 2: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    1. Unplug the power supply from the rear of the product.
    2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
    3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
    4. Wait 15 seconds.
    5. Reconnect the power cord to the power module.
    6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
    7. Check to see if the power module has an LED.
      • If the power module does not have an LED, continue to the next step.
      • If the power module has an LED, check to see if the LED lights up.
        • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
        • If the LED lights up, continue to the next step.
    Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
    1. Reconnect the power supply to the rear of the product.
    2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down.
  • Apr 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
    Getting a 5B00 error on a MX310. We just replaced the ink absorber
    error 5b00
    reset waste absorber counter. here is how to reset.
    1) With the printer2.gif powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
    4) When the LED lights in green, press the Stop/Reset button 4 times.
    If this does not work you need to call canon.
    Good Luck
    Nov 12, 2009 | Canon PIXMA MX310 All-In-One Printer
    Replaced drum on Dell 1720dn printer. Where is
    This should fix the drum light being on that 1720
    Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
    May 13, 2009 | Dell 1720dn Laser Printer
    HP Compaq ProLiant DL380 G4 Server Logo
    284 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
