Question about Moen Posi-Temp Single HandleTub And Shower Faucet
The water doesn't completely shut off at the tub faucet, consistant dribb;e
  • 106 Answers
There is a small rubber ring behind the handle that has worn and needs replaced....good luck.
don't forget to give testimonial and the votes 4 thumbs up if I helped.
Posted on May 29, 2011
Where can I find the water valve shut-off for my kitchen sink
The sink usually doesn't have a shut off of it's own look on the side of your house ,the side closest to the meter & there should be a main water shut off valve for the house.
Jun 06, 2012 | Plumbing
Tap won't turn off
you have a bad cartridge...or bad seats and springs...shut off water pull cartridge and go to lowes or plumbing supply and get parts and replace...make sure hot is on left side before putting back...turn water back on...good luck
Jan 15, 2012 | Danze & Single Handle Tub And Shower...
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
My Roper washer will only work on the spin cycle. It will not fill or work on any other setting. The fill hoses are clear of debris and there is no kink in the drain hose. What do I check next?
The indication you state is consistant with the washer sensing water in the tub. If there is no water in the tub, then it would be the tub sensor. If there is water in the tub, and the spin cycle doesn't get it out, then I would look at the pump or the control board.
Jun 08, 2011 | Roper Washing Machines
I installed a Moen Adler faucet. It will not shut
You may just have a piece of sediment lodged in the cartridge from when the water was shut off during installation. Carefully remove the cartridge and turn the water on to flush out any obstructions. re install the cartridge and test.
Feb 18, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Posi-Temp Single HandleTub And Shower Faucet  Logo
135 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
